The 860 Deal!!!
The 860 Deal!!!
For the guys not familiar with these products. These are the only ones like it on the market. The products are top quality..
Here is what is in the special.
1. The 860 heated Bottle bracket.This unique desighn is best desribed as a bottle bracket wth a billet heated hot plate all made in one. This unit has a adjustable pressure switch that will automatically control your bottle pressure.It also comes with a hex wing adapter and quick release bottle brackets. (NO wrench required to remove your bottle) This unit works well at retaining the heat just like a hot plate!!!! This unit normally sells for 199.00 for -4 and -6 for 207.00.
2. The 860 Bottle bracket mounting plate. This is a mounting plate that goes in the spare tire area so that you can bolt yuor bracket directly to the mounting plate out of the way.No drilling holes where every one can see.This unit normally sells for 45.00
3. The 860 Carbon Fiber bottle ****.This is a new product that was desighned to add a little style to your bottle and give you something to show your buddies.This unit normally sells for 35.00
This whole package is going for 239.00 for -4 applications and 247.00 for -6 applications.
Here are a few pictures.
THIS IS WHERE THE MOUNTING BRACKET FITS.
You can place your order by calling 1-866-648-7637.
Dave
Dave
Formula Steve
Sep 19, 2023 08:31 AM
