B&B Exhaust install
B&B Exhaust install
Ok I took off the stock exhaust and then install the first pipe that connects to the cat. I then try to install the 2nd pipe which runs over the rear end and it just won't fit. I did a search and one person was able to get it through by removing the heat shielding, but I did that with no luck. I went to a couple shops around town and they want 90 to $100 just to finish the install. All that is left is that pipe which has a clamp to connect the two and a bolt on exhaust hanger - then clamp the muffler to the last pipe, clamp provided - and bolt on one last hanger for the muffler.
Does anyone here have exp. with a B&B install or would like to help?
F'n1996Z28SS
Aug 23, 2023 11:19 PM
