1979 Z28 Camaro 355ci 400HP Synergy Green
Old Apr 18, 2013 | 02:28 PM
Collector Car's Avatar
Platinum Vendor
Exclamation 1979 Z28 Camaro 355ci 400HP Synergy Green
Engine:
1991 (Roller) 350 Block .040 over
9-5.1 Pistons with bigger valve reliefs
Stock resized rods with ARP rod bolts
Cast steel crank .010 .010
Hyd Roller Comp Cam (.515 .525 .282 .286)
GMPP Roller Lifters
Comp Cams Timing chain kit
Comp Cams Hyd Roller lifters
Comp Cams Hardened Push Rods
Trick Flow Aluminum Twisted Wedge Heads
190cc 64cc 2.02 1.60
Crane Gold 1.5 Roller Rockers with Poly Locks
Upgraded Valve Springs ( Hyd Roller)
ARP Head bolts
Edelbrock Air-Gap Intake
Holley 750 Double Pumper
Transmission:
Short tailshaft TH350
Rebuilt to handle 500HP N/A
10" 2800-3200 Stall
Fairbanks Shift kit
Rear:
1971 F-body 8.5 10 bolt
4:10 Richmond Gear
Eaton Posi (31 Spline)
Aftermarket 31 spline axles
T/A Rear Girdle
Exhaust:
Hooker 1 3/4 Super Comp Headers
2 1/2 Exhaust front to rear
H-pipe
40 Series Flowmasters
Pypes Trans Am style tips
Miscellaneous:
Custom Autometer gauge cluster
B&M "Slap" shifter
JVC Cd Player
Orion component speakers
600 watt amp 4 channel
600 watt mono
Two 12" Hifonic subs
Brand new gas tank
1/2 Aluminum line front to rear
New Holley Black pump
Giovanna Forged 22's on all four corners
The car is painted a factory 2010 Camaro color (Synergy green)
1979 Z28 Camaro 355ci 400HP Synergy Green For Sale
Feffman
Oct 9, 2015 05:42 AM
ChrisFrez
Dec 15, 2014 03:09 PM
ModdedNerd
Dec 10, 2014 08:42 PM
Bearmans
Dec 3, 2014 05:28 AM
siguy
Nov 27, 2014 10:07 AM
