For sasle 95 Z28 lots of mods, PA
Old Jan 5, 2013 | 04:53 PM
AdamBlackZ28's Avatar
Up for sale 95 Z28 hardtop auto. 2nd owner, bought it completely stock. 77k on the car, about 50 miles on engine and all new parts. This car was my project car for 3 years and i hate to do this but i have to sale it. Need cash asap, on top of that i'm loosing my garage where i keep it in. Car has a LOT mods (see list). Need some body work and paint job. Left door, hood, bumper and fenders are primer. I tried to paint the car piece by piece. I started to fix passenger door (see pics). Driver's quarter panel is damaged (see pics). Interior is in good shape but dash pad is cracked. Car comes with extra auto trans build by Finish Line Transmissions, for specs. see list. I bought this trans from a guy from this forum with very low miles. Here is the list:
Engine/fuel:
Stock block, with stock crank that was checked and polished
Wiseco Pro Tru forged piston kit
Scat Pro Comp I-beam forged rods
New bearings
190cc Ai cylinder heads
Ai Complete cam kit (beehive springs, hardened pushrods, seals, etc.)with 226/234 cam
Comp Cams ultra pro-mag rocker arms 1.6 ratio
Comp Cams OEM replacement lifters
Cloyes Tru Roller timing chain
Summit racing electric water pump
160 thermostat
Trick Flow TB 58mm w/intake enlarged to 58mm
K&N cold air intake
Racetronix 255 fuel pump installed in the bucket
Racetronix 38 injectors
New poly engine mounts
Trans/diff:
Stock trans with shift kit that came with new valves, springs, servos
Yank 3000 stall torque converter
Motive 3:73 gears
New carrier and pinion bearings
New axle bearing and seals
Alloy USA high-stranght axles
Thunder racing diff cover w/bearing caps support
Ignition/exhaust:
MSD cap and rotor
MSD blaster coil
Taylor OVC wires
Peace Setter ceramic headers w/ ORY pipe
Hooker cat back
Suspension:
UMI strut tower brace
UMI rear lower arms
UMI lower arms relocation brackets
UMI non adjustable panhard bar
UMI non adjustable torque arm
UMI bolt on subframe connectors
New sway bar links and bushings
New poly bushing in the front
New lower ball joints
Other:
New maf + map sensor
New ignition control module
New power steering rack and pump
New fuel pressure regulator, non adjustable
New fuel filter
New front hawk pads + brembo rotors
Newer rear pads + rotors
Tires have less then 10k on them
FLT trans.:
FLT machined performance pump.
Media blast case, bell housing, and tail housing to restore a new aluminum finish. Prep case for assembly.
8 B/W hi-energy clutches w/koleen steels in 3-4 clutch
Seal & gasket kit
Bushing kit
Alto wide 2-4 red lined band with reinforced anchor
Bonded pistons/input drum
Sonnax SmartShell kit w/bearing
Extra Wide Heavy Duty double caged 29 element sprag
4L65 low roller clutch
Corvette servo
New solenoids
New internal wiring harness
New Spacer plate
B/W clutches
Updated aluminum accumulator pistons
FLT calibrated valvebody
Filter
Set end play to FLT specs
Case cooler fittings
So there it is, i put a lot of money in to this car and i hate to see it go. I probably missed something on the list. I'm asking $3400 OBO. I need to sale this car before the end of this month. For pictures see my album. I'm located in PA, Philadelphia area. If you are interested e-mail me at amendelewski@comcast.net
Thanks,
ADAM
Noenav
Mar 1, 2019 07:38 AM
cmdeshon
Dec 27, 2014 10:06 AM
FASTFATBOY
Jun 26, 2002 12:06 PM
FASTFATBOY
Jun 20, 2002 11:27 AM
