1993 Camaro Z-28
1993 Camaro Z-28
040 LT1
3.750 FORGED STROKER CRANK
SPLAYED 4 BOLT
BLOCK FILLED TO BOTTOM OF FREEZE PLUGS
H-BEAM RODS ARP BOLTS
DIAMOND PISTONS GAS PORTED , TOP RING LAND LOWERED
TOTAL SEAL RINGS
15.1 COMPRESSION
MOROSO BILLET OIL PUMP
ARP BOLTS THRUOUT
CANTON PAN
ATI BALANCER
COMP. SOLID ROLLER 720/679 LIFT
COMP. ROLLER LIFTERS
PROFILER ALUM. HEAD, FULLY PORTED
MANLEY S/S VALVES 2.08-1.60
ISKY SPRINGS
TITANIUM RETAINERS
T&D SHAFT ROCKERS 1.60-1.55
ARP HEAD STUDS
ALUM. FABBED VALVE COVERS
EDELBROCK STEP HEADERS 13/4 17/8
SCHOENFIELD 4 RACE MUFFLERS
HURRICANE PORTED EFI INTAKE
WILSON 1100 TB
MORAN 65 LBS INJECTORS
MEZIERE ELECTRIC WATER PUMP
AVCO RAD.
MOROSOVACUUM PUMP
MSD CRANK TRIGGER
MSD BILLET DUAL SYNC DISTRIBUTOR
MSD PRO POWER HVC COIL
MOROSO 8MM PLUG WIRES
FRONT & REAR MOTOR PLATES WITH STABILIZERS
SFI FLEXPLATE
ATI 5800 CONVERTER
ATI TH-400 REV. MAN. VALVE BODY with ATI TRANS BRAKE
PST 3 DRIVESHAFT 1350 JOINTS
MOSER 9 REAR 4.56 PRO GEAR , SPOOL, 35 SPLINE AXLES , 5/8 STUDS
HOOSIER 28/4.5/15 DRAG FRONT TIRES
M/T 28/10.50/15 ET DRAG SLICKS
WELD PROSTARS 15x 4 AND 15x 10 RIMS , DRILLED AND SCREWED
SLOTTED AND DRILLED ROTORS
STRANGE MANUAL MASTER CYL. , WILDWOOD PROPOR. VALVE
MANUAL RACK & PINION
EIBACH FRONT DRAG SHOCKS & SPRINGS
FRONT END LIMITERS
EIBACH REAR RACE SPRINGS
QA-1 REAR DBL. ADJ. SHOCKS
BMR ADJ. ANTI-ROLL
BMR/SPOHN TUBULAR A-ARMS,ADJ.TORQUE ARM, LOWER CONTROL
ARMS,PANHARD BAR & D/S LOOP
PAINLESS 8 SW. CURCUIT
AUTOMETER GUAGES & TACH
F.A.S.T. EFI 2.2 SYSTEM w SENSORS
F.A.S.T. DRIVESHAFT DATA RECORDER
MSD DIGITAL 7PLUS
LINE LOCK
8PT. CAGE CERT . TO 8.50 D/S SWING OUT , REMOVABLE WINDOW NET SFI
HURST SHIFTER WITH LINE LOCK BUTTON
NEW HEADLINER
NEW RACE CARPET
MANUAL WINDOWS
ALL LIGHTS WORK
VFN SONOCO COWL HOOD ( PIN ON )
LEXAN WINDSHIELD
LEXAN HATCH
1993 CADILLIAC BLACK CHERRY PAINT
RCI RACE SEATS 7 COVERS
RCI 5 PT. BELTS
RCI 12 GAL. ALUM. FUEL CELL
AREOMOTIVE A-1000 FUEL PUMP & FILTER
AN S/S FUEL LINES 10AN,8AN,6AN & 4AN
POWER SHUT-OFF SWITCH
16VOLT XS POWER BATTERY
16 VOLT ALTENATOR
16 VOLT XS POWER CHARGER
ALUM. BATTERY BOX
S&W REMOVABLE WHEELIE BARS
------------ALL PARTS ARE NEW --------!!!!!!!!!---------------
HP 668 @7600
TQ 503 @5800
Ό MILE 5 RUNS BEST-10.45 @129.99 , SLOWEST 10.56 @129.42 , BEST MPH 130.44
Runs were do from an Idle, never left off of Trans Brake . Shake down runs only !
$22,000, or trade for nice street 67-69 Camaro, 00-02 lo. mi. Vette. I can send pictures to e-mail address
SPLAYED 4 BOLT
TOTAL SEAL RINGS
15.1 COMPRESSION
ARP BOLTS THRUOUT
CANTON PAN
ATI BALANCER
ISKY SPRINGS
TITANIUM RETAINERS
ARP HEAD STUDS
WILSON 1100 TB
AVCO RAD.
MOROSOVACUUM PUMP
MSD CRANK TRIGGER
SFI FLEXPLATE
ATI 5800 CONVERTER
FRONT END LIMITERS
BMR ADJ. ANTI-ROLL
MSD DIGITAL 7PLUS
LINE LOCK
NEW HEADLINER
NEW RACE CARPET
MANUAL WINDOWS
ALL LIGHTS WORK
LEXAN WINDSHIELD
LEXAN HATCH
RCI 5 PT. BELTS
16 VOLT ALTENATOR
ALUM. BATTERY BOX
HP 668 @7600
TQ 503 @5800
F'n1996Z28SS
Aug 23, 2023 11:19 PM
