1969 Camaro 4 spd. Very nice an dependable
Old Oct 9, 2012 | 03:43 PM
Collector Car's Avatar
Platinum Vendor
Exclamation 1969 Camaro 4 spd. Very nice an dependable
This is a 1969 camaro, clone as a Z-28, an has been done right. I will list a few things but won't bore you with every little detail.
If you are looking for a trailer queen, then read no futher, BUT, if you want a very nice 69 camaro, that is very dependable, that you can drive an enjoy, an not have to worry about breaking down or running hot, then keep looing an reading.
My am not a dealer, this is my car. EVERYTHING on this car works..reverse lights,horn,turn signals,side markers,key buzzer,all lights,dome,brakes tails,heat,vents,gas,oil, emerg. brake, etc.. The radio is the only thing that does not, it is the original factory AM radio but new.
Motor is a 350 4 bolt, roller motor, sounds good not too loud, an runs out very smooth an can drive anywhere (has been drove over 300 miles one way, NO problems) has a M-21 4 spd., shifts very smooth, has a 4 core alum. radiator, runs cool even in traffic. Coated headers, an still holding up very good, not turning colors.
Rearend is a 3:42 posi. outlined with 15x8 rear an 15x7 front rally's, with the flat centers, old school look, I do still have the big centers, if you want.
All body lines a very nice, an doors, trunk, hood, shuts very smooth. Trunk is like original, with rally spare an mounted jack.
Interior is very nice, with gauges in the console, an has a tach in the dash, it works, an is correct, all dash lights work.
Paint is very nice an slick an shines good, 8.5 out of 10, (maybe better than 8.5, I'm just picky) car was done frame off in 2008, an has a little over 4200 miles on it of enjoyment
It does have power steering, with disc. brakes on front, new gas tank, stainless lines.. Has the original wiring harness, this car has been well taken care of even before the restoration was started. The trim around the windows is original, have been buffed, they are near perfect condition, so you don't have the gaps, of the repo's. All glass is new except pass. door, it is good, an they all roll down. Seat belts in front only. Has a one peace floor pan installed, along with both quarters replaced, an did a very good job.
The car runs, drives, handles, super, you will be superised how easy it handles an drives. This car has been drove to all shows an has done great, very few nicks from driven, just a very good car, that everything works an you will feel safe to drive, anywhere.
I do have alot of reciepts, but not all, an not counting paint, an labor work of the disassemblly, can't find the pictures.
Any questions you can call, if you are serious, I am about 25 miles from Knoxville, Tn. (865) 850-7516, Thanks for your time
F'n1996Z28SS
Aug 23, 2023 11:19 PM
njspder
Middle Atlantic
Jan 8, 2015 11:13 AM
Collector Car
Jan 5, 2015 10:58 AM
Collector Car
Dec 17, 2014 01:12 PM
