coolant reservoir hose is cut
Old May 28, 2012 | 09:46 AM
aknight_sa's Avatar
hi all,
been having overheating issues and water was always getting low but slowly.. after checking the hoses and radiator i found that the hose which is at the reservoir side is cut and water escapes from there.
i took the reservoir out but found that the hose is sealed on with a metal ring...
how can i replace this hose? and btw, the hose is connected to a metal pipe which goes in the reservoir... can i take that out or not??
Old May 28, 2012 | 07:06 PM
Re: coolant reservoir hose is cut
Replace with a section of hose and a clamp. The factory part 10188032 may be discontinued. Gotta have that hose in place.
calaban
May 18, 2020 06:43 PM
MattFick
Feb 15, 2015 10:16 PM
94Z28LS1toLT1
Jan 15, 2015 07:18 PM
ddr698
Dec 31, 2014 09:16 AM
