Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
94 LT1 revs up when warmed up
Old Oct 13, 2011 | 08:45 PM
dscottd's Avatar
My 94 Z/28 has a LT1 350, 79000 miles on it. After it get up to operating temps it will rev up to 2000rpm when sitting at a traffic light or stop sign. I have had it to several Chevy Stores and no one can find what is causing this problem. I had the throttle body cleaned out and have ran several cans of Sea Foam with no results, same problem. I know it needs new plugs and wires which I will put on this winter, but what the H**l is causing the reving up problem? Anybody else have the same problem?
Old Oct 13, 2011 | 08:59 PM
JGuy07's Avatar
Re: 94 LT1 revs up when warmed up
Maybe not the exact same, but I have an idling issue. We've checked almost everything from vacuum lines to sensors and the iac valve with no luck. I believe I'm still picking up air from somewhere(vacuum leak) which is causing the high idle. All me sensor volts are within spec and I'm lost as to what it could be.
So try checking the vacuum lines for leaks and go over your iac valve and tps one more time to rule them out for sure.
Old Oct 25, 2011 | 12:18 PM
nintythreeZ28's Avatar
Agreed. Any vacuum leak will cause the motor to rev. But the only flag thrown in my head with this theory is why is it only when it is warm? This leads me to believe it may be iac valve, possibly an o2 sensor.
To further diagnose the problem we need to know about your car. Try setting up a signature with year and any mods of your car.
Old Oct 25, 2011 | 12:37 PM
Psycho's Avatar
The map sensor is often overlooked. It has a rubber seal that can go bad or leak.
Old Nov 1, 2011 | 07:14 AM
jproz1167's Avatar
My friend bought a 94 z28 that does this. misses alot, sometimes idles up to 2000rpm, failed smog test (super high HC and NOX) no service engine light has come on. It is also very hard to start at times .... sorry for hijacking anyone have a clue on this? Also has a K & N cold air setup on it but has some weird vacuum line plugged into the intake elbow with what looks like a 1 way check valve.
Old Nov 7, 2011 | 07:58 AM
jcl69cam's Avatar
Try taking the vac line off of your EGR valve and plugging it, see how it runs after that. Mine did the same thing. Good luck
Old Nov 16, 2011 | 01:55 PM
or just delete the egr valve as a whole.
94Form
Feb 10, 2015 11:23 PM
Gtpguy
Jan 26, 2015 04:50 PM
Jan 23, 2015 01:13 PM
Injuneer
Dec 15, 2014 09:36 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
