My 94 feels loose after alignment
Old May 26, 2011 | 10:21 AM
cyteone's Avatar
I have a 94 formula and recently took it in for an alignment. On my way home I noticed that it shakes more when I hit little bumps. It feels like something is loose. I was thinking I should check bolt tightness on the front end. What would they have adjusted for an alignment? I want to check everything to make sure it tight. Any insight as to what to check would be a great help.
Thanks.
Old May 26, 2011 | 02:09 PM
cyteone's Avatar
Re: My 94 feels loose after alignment
Printout specs from alignment
before alignment:
left right
Camber -0.5 -0.4
Caster 6.3 5.3
toe -.46 0.2
cross camber -0.1
cross caster 0.9
total toe -0.26
set back -0.10
After alignment:
left right
Camber -1.3 -0.8
Caster 5.4 5.0
toe -.02 -0.03
cross camber -0.4
cross caster 0.4
total toe -0.04
set back 0.18
Old May 27, 2011 | 08:11 AM
95TA04GOAT's Avatar
The after readings look good. Check the lower control arm pivot bolts. That's what would have been loosened to move the lower control arm to adjust the camber / caster.
92_RS_305
Sep 8, 2015 07:47 PM
Mir Hussain
Outside of United States
Aug 8, 2015 07:00 PM
Z28-50
Aug 7, 2015 01:22 AM
techstar
Aug 6, 2015 11:20 AM
C4m4roJoe
Jul 19, 2015 10:59 PM
