Camshaft Identification?
Old May 16, 2011 | 10:54 PM
Geoffmj's Avatar
I cant remember the specs on it. It should be comp camps. Tried searching on their website without much luck. Ground into it are:
31225/31205
HR113
CC
N2803
-08 (might be 108)
If anyone can help me out it would be much appreciated. Thanks
Old May 17, 2011 | 11:48 AM
Bersaglieri's Avatar
Re: Camshaft Identification?
Well Comps lobes for 3122/3120 is a 236/244 @ .050, HR usually means hydraulic roller, and 113 I'm going to assuming is the LSA. The lift for those lobes are .608/6.13 with 1.6 rockers. The lobes fall under the high lift magnum series and the Advertised duration listed is 290/304, hope that helps. Maybe try calling comp?
-Dustin-
G-BODYT56
Jan 14, 2022 11:14 PM
95chwagon
Oct 16, 2015 12:24 PM
football4life
Oct 4, 2015 07:48 AM
Daluchman1974
Sep 11, 2015 06:12 AM
95z_28_camaro_4_Ivan
Aug 25, 2015 03:59 PM
