Supporting Vendor Group Purchases and Sales GPs/SALES CAN BE MADE BY SUPPORTING VENDORS OF THIS SITE ONLY!
New Rear Lower Control Arms and Rear Toe Links for your 2010-2011 Camaro
Old Nov 15, 2010 | 03:44 PM
PFYC's Avatar
Featured new suspension products at PFYC-PartsForYourCar.com.
Independent Rear Suspension (IRS) systems provide a good balance of ride comfort, road feel, and traction; however wheel hop commonly plagues these designs due to weak stamped steel and rubber bushings. Lakewood engineers have spent countless hours finding solutions to this problem without sacrificing the inherent balance of these systems. Lakewood trailing arms strengthen the rear suspension and improve traction by reducing wheel hop.
Please click photos below to go to the ordering pages.
Lakewood Rear Lower Control Arms for Camaro
Factory toe links in IRS systems can bend and deflect under load, which in turn alters toe alignment settings. This not only can cause inconsistent handling, but also alters the tire's contact patch under load. Lakewood toe links are stronger and eliminate these inconsistencies which can improve lateral grip, shorten braking distances, and improve stability under load.
Lakewood Rear Toe Links for Camaro
To see a full line-up of our new products for your 2010-2011 Camaro, please click here.
To see a full line-up of our current sales and specials, please click here.
Old Nov 16, 2010 | 09:26 PM
JasonD's Avatar
Admin Emeritus
Re: New Rear Lower Control Arms and Rear Toe Links for your 2010-2011 Camaro
Good for street or just racing?
Old Nov 17, 2010 | 11:04 AM
PFYC's Avatar
Absolutely fine for the street. However, any time you're replacing rubber bushings with urethane bushings, you may notice some deterioration in ride quality, depending on which bushings you're replacing and how much influence that bushing has on ride quality. Most people wouldn't notice much deterioration in ride quality with these but some would.
Old Nov 18, 2010 | 09:22 PM
JasonD's Avatar
Admin Emeritus
Good info, thanks Mike!
oldschool
Feb 9, 2016 09:21 PM
thenewkid
Nov 27, 2014 09:41 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
sc93
Jul 26, 2002 02:02 PM
