82-92 parts. 383 shortblock Comp Rockers, OBDII setup, TF Heads, LPE219, SLP Headers.
Old Jun 11, 2010 | 06:57 PM
Mkos1980's Avatar
I've decided I've had this combo long enough and its time to go extreme. Looking to sell.
383 Shortblock. Block is an 89 block one piece. 2 bolt main. Has about 25-30K miles on it. (Runs awesome) Eagle cast crank, Eagle Forged H beams. (I beams had trouble so they upgraded me for free) and Hyper SpeedPro pistons. Deck was line honed. ARP main studs. block was deck. Entire rotating assembly was internally balanced. Only problem was when they were building the engine. there was small crack in the lifter valley. It was drilled and pinned. . No Issues. Oil pressure is 25-30 HOT with it 80+ outside and being at a 600 idle. Doesnt burn an ounce of oil. Comes with Miloden Oil Pan. Engine was professional built by Victory Racing in Cleveland Ohio. Make Offer
Trickflow 23* heads.87-95 Centerbolt Springs are duel's for 600 lift. Hyd Roller Springs Make Offer. BTW, Comes with a full set of ARP Head Bolts.
LPE 219 cam. 219/219 560/560 112 LSA $125 shipped.
Comp Cams Pro Magnum 1.6 Rockers. Must be used with plates Much Better then the Crane Golds. Fits under stock valve centerbolt covers. $175.00 Shipped.
full valvetrain. Lifters, hold down ,dogbones ect. Roller Stuff. $40.00 shipped
Holley 52MM TB Very nice shape. I have the origional Holley TB Plate for it. I'll also throw in the WS6 Plate. $235 Shipped
OBDII 411 Swap Pieces. Knock sensor, Vortec timing Cover, crank sensor, accel Billetech distributor, reluctor ring, shortened balancer, MSD Coil, Taylor Red Spiral Pro Wires, and Vortec timing chain. $350.00 + Shipping
Brand new never used stock starter SBC. $35+ Shipping
Ac Delete Pulley. $35.00 Shipped.
March Underdrive Polished crank and alt pulley $50.00 Shipped.
Used autozone gold Alternator. Works perfect. $40.00 Shipped
Email Mkos1980@aol.com Thanks
Old Jun 11, 2010 | 09:05 PM
IROC-Z28_CAMARO's Avatar
how many km on the cam. You have any pics of the lobes and cam itself.
Old Jun 11, 2010 | 09:09 PM
Mkos1980's Avatar
Cam has 2,000 - 3,000 miles on it. I can get pics. I bought it straight from Lingenfelter. The engine is coming on on Monday. So I can get pics then.
Selling everything because Im doing a boosted LSX motor.
Old Jun 12, 2010 | 06:35 AM
please send pics to
josh_camaro@hotmail.com
when you get it out.
oldschool
Feb 9, 2016 09:21 PM
MadMav
May 25, 2015 09:35 PM
Chevyguy358
Jan 28, 2015 08:04 PM
CaRParts102
Dec 6, 2014 08:45 AM
