Fs:lt1 engine parts
Old Jun 3, 2010 | 08:01 PM
quiklt1's Avatar
Fs:lt1 engine parts
i have a couple stock parts pulled off of lt1 engine i picked up to rebuild.
1. b-body accesory bracket no stripped bolt holes and no cracks $40 shipped
2. Stock lt1 intake manifold with no sensors but comes with all fittings no t/b fuel rail or injectors $45 shipped
3. Stock Lt1 cast iron heads complete with rockers,springs,retainers,and valves stock unported and not cracked 66k miles heads off of 95 imp ss $180 shipped for both.
4. Oil pump drive gear i have about 3 of these $25 shipped each
5. Stock throttle bodies i have 2 of these no sensors and no bottom iac housings $25 shipped
6. 94-95 lt1 front timing cover undamaged SOLD
7. 94-95 stock coil with ICm and heat sink the plastic connector part of the icm is cracked but plug will still plug into it $25 shipped
8. SET of BRAND NEW IN THE BOX AC DELCO 41-906 PLUGS 8 IN TOTAL $40 shipped
9. lt1 engine mounts the ones that bolt to the block the clam shells as they are called SOLD
10. Stock LT1 fuel rails with regualtor with injectors PENDING
11. lt1 Hydraulic roller lifters,valley spider and lifter guides will also include pushrods. this is great for some one trying to do a roller conversion $45 shipped
12. Stock lt1 b-body cam good shape no wear or scrathes out of 66k mile imp ss $40 shipped
13. Stock lt1 Flexplate $25 shipped
14. Stock Lt1 oil pan no dents will come with rails SOLD
15. lt1 oil filter adapter base with bolt allen screws for adding an oil cooler to car with out oil cooling option $25 shipped
16. Lt1 b-body COre non working ac compressor $25 shipped
17. lt1 one piece seal rear retainer SOLD
i accept paypal
Old Jun 12, 2010 | 01:22 AM
quiklt1's Avatar
prices and parts edited.
Old Jun 15, 2010 | 04:20 PM
quiklt1's Avatar
anyone
oldschool
Feb 9, 2016 09:21 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
siguy
Nov 27, 2014 10:07 AM
