1995 LT1 Complete Engine for Sale (355 ci)
Old May 12, 2010 | 07:34 PM
TransAm-Z's Avatar
(SOLD)
1995 LT1 Complete Engine for Sale! This engine is still in my 95 TransAm if anyone is interested seeing it run before they buy. Car runs a 12.1 @ 111 mph with this setup at 1000ft and 3600 lbs. I am selling this setup to fund another car project. Great street/strip engine (fun to drive).
Here are video links shot with the cut-outs open.
http://tinypic.com/player.php?v=hrj5z7&s=6
http://tinypic.com/player.php?v=hv1fv9&s=6
AI Ported LT1 Heads (Flow 260 Intake, 191 Exhaust http://www.advancedinduction.com/ )
Beehive Springs (Comp Cams #CCA-26918-16)
Spring Retainers (Comp Cams #CCA-795-16)
Valve Locks (10 deg.) (Comp Cams #CCA-614-16)
Spring Seats (Comp Cams #CCA-4705-16)
Roller Rockers (PRO-MAGNUM) 1.6 Ratio 7/16" Studs (Comp Cams #CCA-1305-16)
Hardened Pushrods (7.100") (Comp Cams #CCA-7938-16)
Hardened Guide Plates (Comp Cams)
355 Short Block (2500 miles)—Rebuilt 2009
Performance Head Gaskets (0.039") (Felpro #FPP-1074)
Hyptectic pistons (12cc) (K.B. #UEM-KB193030-8)
Ring Set (Plasma Moly) (Sealed Power #SLP-E-251K)
Rod Bolts (ARP #ARP-134-6403)
Main Studs (Milodon #MIL-81150)
Head Bolts (ARP #ARP-134-3601)
True Roller Timing Set (Cloyes #EX-187)
Lifters GM Hydraulic
Comp Cam 224/230 (Comp Cams #CCA-07-503-08)
Oil Pan (7 Qt. Capacity) (Milodon #MIL-30902)
Windage Tray (Milodon #MIL-32102)
Oil Pump (High Volume/Pressure) (Milodon #MIL-18750)
Oil Pickup Tube (Milodon #MIL-18314)
Composite Corvette Valve Covers
Electric Water Pump (CSI #170-901LT1)
OptiSpark (GM #1104032)
Port Matched GM LT1 intake (Inlet openings Machined for 58mm TB)
(Does not include Accessories, T.B., or Injectors)
Block Machine Work Includes:
Bore Block 4.030 & T.P. Hone
Align Hone Mains
Resize rods
Deck Block
Polish Crank
Balance Rotating Assembly
Engine Specs
Head Volume: 55.9cc
Dish/Dome Volume: 12cc
Gasket Thickness: 0.039in
Gasket Bore: 4.100in
Deck Clearance: 0.000in
Stroke: 3.480in
Cylinder Bore: 4.030in
Quench: 0.039”
COMPRESSION RATIO 10.53
DYNAMIC COMPRESSION 8.35
$3900 (SOLD)
Old May 13, 2010 | 08:04 AM
brad3579's Avatar
[QUOTE=
$4500 (Will ship, but Local Pickup preferred, also will meet halfway within reason!)
[/QUOTE]
Where are you?
Old May 13, 2010 | 11:14 AM
TransAm-Z's Avatar
Originally Posted by brad3579
Where are you?
Tipp City, OH 45371 (Close to Dayton)
Old May 14, 2010 | 04:49 PM
TransAm-Z's Avatar
New Price
Price dropped to $3900
Old May 18, 2010 | 05:51 PM
TransAm-Z's Avatar
Here is a link to a video shot with the cut-outs open.
rocketman051894
Jan 30, 2015 03:23 PM
4586
Jan 3, 2015 07:22 PM
NorthPoleDev
Dec 31, 2014 03:20 PM
Not Dave
Dec 11, 2014 06:32 PM
94z28jbw
Sep 8, 2002 03:22 PM
