LT1 parts galore!!!
Old May 12, 2010 | 03:42 PM
SPEED#1's Avatar
LT1 parts galore!!!
Racetronix 85# flow matched low impedance injectors - Less than 1000 miles total. They cost $480 plus shipping from Canada when new. I will take $400
Comp cam - 230/236; .571/.576; 114+1 (1.6 rockers) Cam card included. Mileage is same as the block listed below. $275
MSD Digital 7 ignition box - Part # 7520. Same useage as the injectors above. Was mounted inside the car, so its never seen heat or anything damaging. Brand new cost $530.00 plus shipping, I'll take $400
MSD HVC II ignition coil - Part # 8261. This is probably the best coil MSD makes. Its not intended for street use or GM Opti's, lol. New price is about $175 plus shipping... I'll take $125 o.b.o.
MSD Plug black wires for 93-97 Lt1 F-body. I'll take $85
Package deal for above ignition components (Box, Coil, Wires) I'll take $575
TH400 swap package - Id rather not sell these parts seperately, but prices are listed below if sold seperately
*Built RMVB TH400 with Hipster Trans Brake $1400 (built by Transmission Physicians)
*Precision Industries 9.5" spragless converter (stalled around 4500 on the brake behind my supercharged 383) $550
*JW 'The Wheel' flex-plate (168tooth, 1pc seal, internal balance) $150
*Denny's Nitrous Ready drive-shaft (with the big U-joints) $400
*T56 cross-member with Spohn TH400 adapter, and a trans blanket. $150
Alot of money invested into this set-up. I will only seperate if I have buyers for all the parts. I will take $2000 for the package
Mileage on parts listed below: 1500 break-in, 2 dyno sessions, 3 - 1/4mile passes, and a couple short cruises to local shows (maybe 25miles total for the cruises)
Heads: Ported Stock castings, extensive port cutting/welding/epoxying. Ported by Port Pros out of Austin, Tx
Valves are Ferrea(sp?) 2.02, 1.60 diameters. +.250" stem length (for spring installed height)
Comp BBC 'Beehives' These are NOT the SBC/LT1 version of the Beehives.
198cc's runners, heads milled to 69cc
Flow sheet included. Intake peak 285cfm @.600
Heads were around $1800 new, like to get $900
383 short-block: $2500
Eagle H-beam rods, Eagle 4340 crank, SRP forged pistons (flat top w/valve reliefs), Rings are JE Hellfire. No head gaskets in place, head deck is machined for Cometics. 9.4:1 w/69cc
Includes: Canton 7qt pan, ATI balancer with large OD hub, custom modded timing cover for the big balancer hub and water pump drive delete, Cloyes Double Roller timing set, Comp R lifters (before they changed to the bad design), Have a set of ARP head studs, and Comp Pro Mag pushrods that are matched to the block/head/valvetrain combo. Also have a set of reuseable Cometic Gaskets.
Old May 12, 2010 | 06:37 PM
fbody93's Avatar
Did you take some metal out of the combustion chamber to get to 69cc on the heads?
Old May 12, 2010 | 06:54 PM
SPEED#1's Avatar
extensive port cutting/welding/epoxying was done to the heads and it worked awesome on this combo.
Old May 13, 2010 | 12:38 PM
SPEED#1's Avatar
need gone guys, best offer accepted
Old May 13, 2010 | 01:11 PM
cool_breeze's Avatar
How about you refund my money for the heads I never got! The BS tracking number but no heads delivered and not answering PM's.
Old May 13, 2010 | 09:33 PM
01CamaroSS's Avatar
hey cool breeze what is the tracking number you got because I got one aswell and fed ex doesnt know where the box is or if they even have one. This is rediculous...... PM me. I give William, the benifit of the doubt on all this stuff and still hope they come but this is crazy.
Old May 13, 2010 | 11:05 PM
my1994z28's Avatar
This a hole is a scam guys!!!!!!!!!!do not buy anything from him
Old May 14, 2010 | 12:05 AM
01CamaroSS's Avatar
I hope not bro 1250 bucks is gone otherwise, but I have a feeling ur right..... unless I see the heads and they are what I ordered, I mean fed ex loosing a shipment? or he didnt send them i got a bs #. he got my money I sent him many pms he replied to them but I contacted the mod. and someone else told me they got ripped? see an above post. Like really? come on now we wont hear from him, it really sucks. All this just doesnt make sense!
Old May 14, 2010 | 03:34 AM
I replied to your PM 01CamaroSS
Old May 14, 2010 | 09:20 AM
Verz's Avatar
Funny he wont reply to pms but he continues to post up more items for sale, guy is bold. Good luck to you both on getting your items or your money back.
Old May 14, 2010 | 09:38 AM
ddr698's Avatar
I remember when this guy first joined and posted A LOT of what seemed to be rather pointless posts in misc threads. Seems to be what ppl do to build up some post count in order post up stuff for sale.... Hopefully im just nitpicking.... but in any event Im hoping you paid with credit cards thru paypal? If he took the money and ran paypal will be helpless but your credit card companies WILL get a reversal from paypal. File with them now if you were so lucky to pay with this method....
Old May 14, 2010 | 11:00 AM
I hear ya brother and yeah there's certain things I use a credit card for and online purchasing is one for sure, some people don't believe in credit cards but I use them for online shopping for that reason. You are correct paypal is useless and I have already filed with my credit card, my credit card is through my bank that I bank with so I know they will help me out. He doesn't even reply to PM's just keeps listing things for sale, and he is still doing random post on threads.
Old May 14, 2010 | 12:21 PM
ddr698's Avatar
Good to hear you paid with cc...
I would love to see how 54cc stock castings were made into 69+cc and then "milled to 69cc" combustion chambers.... Ive gotta pull out the BS flag on that one....
Old May 14, 2010 | 12:27 PM
camit282's Avatar
$2000 for the th400 swap i can get the parts new and do it cheaper then that...
I would never buy off this guy
Old May 14, 2010 | 01:00 PM
na it's really $2000 for a tracking number cause that's all you'll get and that's an expensive tracking number!
