Starting issues when cold outside
The car would do this sporadically throughout the early Fall but now that it is cold (30s) in the morning when I leave for work I'm having a hell of a time with it.
The car fires right up but within a few seconds of idling just dies. I crank it again, starts right up again...dies. This goes 2-3 times and it finally levels off and idles fine. After a couple of minutes its good to drive. I am also experiencing a high-rpm breakup once the car warms up a bit. Opti was replaced a year ago (genuine GM)...has about 6k on it.
My tune has some issues, and the car is running pretty rich. Other than that there are no real issues otherwise. No codes and I don't want to start blindly replacing parts. I also tried the search function but didn't have much luck since the keyboards "cold start" really had nothing to do with outside temp.
Might want to check your TPS voltage too.
Gtpguy
Jan 26, 2015 04:50 PM
Alex Barnes
Jan 24, 2015 10:21 PM
Jan 23, 2015 01:13 PM
