WTT: 87 Buick Regal TTYPE
I would like to trade my 87 TTYPE for an fbody,preferably a 6speed,but autos will be considered......
If I have to put a cash price on the car Id say $5800 obo....
The Regal has
-NEW TA49 turbo
-42.5 lb injectors
-Turbo Tweak Chip
-HURST Roll control
-Billet Aluminum Fuel pressure regulator
-Stainless Steel braided line with fuel pressure guage
-Upper plenum spacer
-NEW Turbo inlet bell
-Ceramic coated Turbo shield
-3'' powder coated up pipe
-3'' powder coated maf pipe
-Billet Aluminum oil tube with K&N filter in valve cover
-CK Performance Stage 1 transmission with 10000+/- miles
-PATS 3000 stall lockup converter
-Terry Houston 3'' Stainless Steel downpipe
-Stainless Steel 3'' Dump Tube
-DMH electric cutout
-2 1/2'' Dual exhaust with Flowmaster mufflers
-Comp Cams valve springs
-Aftermarket Cam (not sure what type or brand)
-Adjustable Wastegate
-Blowoff valve
-NEW Energy Suspension swaybar bushings
-Hotchkis lower and upper rear control arms
-Koni adjustable shocks in rear
-ebaich lowering springs in rear
-Header flanges cleaned up and drivers header welded
-K&N cone filter
-Engine tie down
-NEW rear brakes and wheel cylinders
-NEW AC Delco R43TS spark plugs
-2 guage pillar pod
-Autometer Sport Comp Silver A/F Ratio guage
-Autometer Sport Comp Silver Boost guage
-Autometer Sport Comp Silver Mini tach w/ pen shiftlight
-Pioneer CD/MP3 player
-Pioneer Speakers in front and rear
-16' GTA wheels
-NEW alternator only 100 miles
Stock wheels included
The bad:
Car needs some bodywork. The interior is faded and seats are ripped.A/C isnt working,missing the lines. The dash light doesnt work...
Car ran a 12.4@109 in the 1/4 with the stock down pipe and stock trans..
I will also include another block with crank and cam,and a brand new set of .20 over pistons..
The Regal has
-NEW TA49 turbo
-42.5 lb injectors
-Turbo Tweak Chip
-HURST Roll control
-Blowoff valve
-K&N cone filter
-Engine tie down
-2 guage pillar pod
-16' GTA wheels
The bad:
Hi i would love to see all the pic you have. Also of some good shots of the body work you said it needs.
silveradodriver27@msn.com
Also could i get your phone num or you can call me at 920 210 9448 Kyle. Thanks again
The body work,is it just needs paint on the driver side rear quarter panel,and needs rear bumper fillers...
No other issues,I drive the car everyday... Car has 136k miles on it.... title is clean and car fax is clean.
Bump...
Still looking for a fbody....
The buick now has a SMC alcohol injection kit,can now run 25lbs of boost safely...
Took the car to the local 1/8 mile track on some crappy street tires,and it ran 8.2 @ 88 with a crap 2.3 60' no boost off the line.. Id almost guarantee the car will go a 7.7 on a sticky tire and a sub 1.8 60' .....
