10 second 69 camaro --$$15,500
Old Sep 22, 2009 | 07:28 PM
detroit1994z28's Avatar
Listed again is my fathers 69 camaro.
Built 427 bbc N/A close to 700hp 13.5 compression all the best parts, fully forged, csr waterpump, aluminum radiator
trans- built th400 w/ reverse valve body, 4k torque converter
rearend- 12 bolt rearend spool w/ 488 gears - mini tubbed
Interoir is all brand new - custom autometer dash, racing seats, carpet, fully caged, etc,etc -- everything is brand new just re-done
Exteroir - body is solid no rust at all.
Wheels - prostars skinnys/meats in the rear all new w/ new tires/drag radials
Car runs mid 10's in 1/4 all on motor - runs on 110 leaded - has a 8 gallon fuel cell. Car was a drag car but converted back to street. Motor is very healthy w/ 80psi of oil pressure.
[imghttp://img32.imageshack.us/img32/7761/sdc10021p.jpg][/img]
Were asking 15,500 - Sorry but this price is firm we not go any lower then this asking price. There is a couple things that should be mentioned about this car - this car was painted several years ago w/ Lacquer paint about 40 coats. So it is cracking alittle but the paint is okay about 7out of 10. The car needs a speedometer cable hooked up to it for the speedometer to work. Will need a turn signal switch for the lights to work -
Jazsun
Dec 29, 2014 12:14 PM
Queens94z28
Dec 20, 2014 09:11 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
