1986 Pontiac Firebird 2.8 V6 A4 $1000 OBO
$600 OBO
Gaithersburg, Maryland
1986 Pontiac Firebird 2.8 V6 A4. Metallic Blue hard top. Car runs and drives just fine, read the bad section below.
Good:
36/23 Front / Rear sway bars with poly bushings.
Front and rear brakes were completely redone in the past year.
Kumho Ecsta ASX tires with 18K miles, still in good shape.
Headlights converted to 87+ style with Headlight Control Module instead of relays.
Ebay Cold Air Intake(cheap but effective)
All the steering components have been replaced in the past year, along with both front wheel bearings.
Interior is in really good shape. Dash pad is NOT cracked. Console lid is NOT cracked(though latch is broken).
Drivers seat has some tears, but the seat cover hides those and blends in well with car.
All the lights work on the dash., as well as brake and headlights.
BAD:
Car is consuming coolant. Oil and coolant are not mixing, but coolant is disappearing.
I feel it is the head gasket.
Passenger side headlight motor works, but the bushings need replacing, so the headlight doesn't always pop up when you turn the lights on.
Front bumper and hood have paint chipping, front bumper is damaged from something heavy pressing down on top. (I will include a hood and bumper in good condition)
Car needs some work, but for a 23 year old car it is in relatively good shape. Still drivable, just have to add coolant before it burns off enough to cavitate the water pump and overheat.
$1000 OBO
Good:
BAD:
$1000 OBO
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Brake_L8
Jan 20, 2015 09:44 AM
