'96 Camaro Z28 6 Speed FS: Needs TLC
Old Aug 26, 2009 | 02:21 PM
Flmac02Z's Avatar
1996 Chevy Camaro Z28 with Manual 6 Speed Transmission
Car is Located in Tallahassee, FL
86,000 Miles with bolt-on modifications:
Pacesetter Long Tube Headers with OR Y Pipe
Corsa Cat-Back Performance Exhaust System
K&N Performance Air Intake
Custom 2000+ Degree Spark Plug Wires
Goodyear 100,000 High Miler Coolant Hoses
Replaced all components of cooling system including: Radiator, WaterPump, Overflow Box, Radiator Cap
Interior:
Original cloth interior with floor mats
B&M Ripper Shifter (Short-Throw)
Replaced center console with 97+ Center Console for more cup holders & Center Console storage
Pioneer Head Unit with AUX input headphone jack
Manual Engine Fan Switch (SLP Switch for Factory Electrical Fans)
Replaced Dashboard Top with OEM from dealership
Replaced Window & Lock switches in both doors with new ones from dealership, old ones were too faded
Majority of all original parts are included including center console and engine headers.
Needs TLC: Issues to be Addressed:
1. Blown Head Gasket - During issue of coolant over-flow leak(where water/coolant is added) engine overheated briefly causing blown head gasket.
There is no visible leak from the car or much, if any, blue smoke when driving but car is eating coolant/water. Needs ~1/2 gallon of water/coolant before driving anywhere. The few times i've driven it i've let it warm up 2 minutes and then run the fans on high the entire drive, never goes above the notch between 160 and the middle line.
2. Paint needs to be touched up, spidering of paint on front and rear bumper as well as some black paint peeling from roof from sun exposure.
3. Interior headliner is hanging down mostly on passenger side and needs to be repaired
4. Passenger Window Motor is dead
5. Power drain from car that needs to be tested for (most likely in passenger window motor which was a replacement from ebay)
Car will charge up and start almost instantly. In trying to fix the charging issue earlier on I have already replaced the alternator, battery, and starter (LT4 starter)
Kelly BlueBook (kbb.com) displays $4100 for Fair condition and does not take into account the performance modifications I have made to it or the head gasket repair.
Please e-mail me offers or questions of any kind as I am trying to sell it.
Pick up preferred but negotiable depending on location.
Thanks,
~Kevin
Tallahassee, Fl
Old Aug 26, 2009 | 04:57 PM
Camaro350z28's Avatar
you have pics?
Old Aug 26, 2009 | 06:52 PM
87slyroc's Avatar
interested if you have some pics.
Old Aug 26, 2009 | 10:46 PM
Flmac02Z's Avatar
Pics
Knew I was forgetting something. Pics up, let me know if you need any different angles or shots
Old Aug 28, 2009 | 06:36 PM
87slyroc's Avatar
pm me with what you are looking to get. also, how far can it drive before overheating?
CamaroHeed
Mar 18, 2020 09:50 PM
Brandon Wittmer
Dec 3, 2014 09:28 PM
siguy
Nov 27, 2014 10:07 AM
grendal
Apr 15, 2010 05:20 PM
2000silverz28
Jul 20, 2002 06:14 AM
