Anyone ever put dual cooling fans on a 3.4?
Old Aug 23, 2009 | 06:29 PM
Sixer-Bird's Avatar
I was wondering how hard this would be to do on the Camaro in my sig.
I plan to do an LT1 swap down the road, so it will need to be done anyway eventually.
Old Aug 24, 2009 | 04:50 AM
95camaroinok's Avatar
I wired in a set from an LS1 car on my 95. Fans sit in the same brackets your single fan does. Perfect fit. Very noticable difference in temps and effectiveness. I wired mine up with relays, one runs to the battery and my aftermarket temp sensor, the other is set up to kick them on with the factory feed wire-A/C on remote wire. I plan to wire in an override switch when I get some time, Will only be one more wire to run in to the switch and tap into my current relay. The dual LS1 fans do pull a chunk when they kick on, not really good for the alternator set up this way, but I can live with it. Im guessing the LS1 cars are somehow wired up for soft start or just a bigger alt. that can handle the amp draw at startup better.
Old Aug 24, 2009 | 08:14 PM
Sixer-Bird's Avatar
I think the LS1s had a bigger alternator. I'm basically going to try to get it to work on the stock relays I have now. I think the V8 cars have an extra one though, not sure how that will work out.
Thanks for the info.
MattFick
Feb 15, 2015 10:16 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
4586
Dec 31, 2014 02:21 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
Jul 4, 2005 05:00 PM
