97TA 84,000 miles $6700 obo
97 Trans Am, Red, A4, leather,T-tops, very well maintained and runs strong w/no leaks. The car is mostly stock with bolt ons, engine is all stock internals. If I forget a few things I'll come back and update, but here is a list of recent maintenance and mods on the car. SLP loudmouth cat-back, K&N cold air, Trans-Go HD2 reprogramming kit, LT4 knock module,throttle body bypass,160 T-stat, PCMforless tune, Edelbrock sub-frame connectors, Taylor 8mm wires(new), new plugs (autolite platinum 104's), MSD blaster coil,new brakes w/slotted rotors up front, new GM Optispark @ approx 15k miles ago, all fluids changed including rear end with Mobil 1 75/90 gear oil and gm limited slip additive, new fuel filter, new clear corners on front. Tires are almost brand new~95% tread left.
known problems are listed below
interior: top dash panel has a crack in it, stitching on top of rear seat is splitting in two places, front seats are still good with no cracks,
exterior: I'd rate it a 7 out of 10-front bumper and hood have several chips that have been touched up. It looks good from anything more than a few feet back but if you get up close you can see the touched up spots.
Mechanical-ABS inop light just came on last week and I have not had time to diagnose it yet, other than that it has no mechanical issues.
The car is located in New Castle De, if anybody has any questions or wants more info please call my cell @302-561-0313
Thanks for looking- Jesse
