95 firebird roller
95 firebird roller
it's setup by madman and this is a list of stuff on the car
OED7855P Front shocks - single adjustable
$184.95 ea you need 2 $370
15FB275 275 lb. front spring - recommended for drag racing $61.95 ea you need 2 $124
DTC2502P Rear shocks - double adjustable $306.95 ea you need 2 $614
BCA001 - Boxed control arms - $174.95
MPHR002 -Chrome moly "On-Car" adj w/poly ends-$159.95
XSB001 fits moser 12bolt '82-2002 F-Body with 3"-3.25" axle tubes $449.95
XTREME Rear Anti-Roll Bar
XTREME
TORQUE ARM
XTA001 - '82-2002 F-Body $659.95
Front A-Arms Part # AA001 1993-2002 F-Body - Standard $249.95 pr
Lower A-arms:
Part # AA002 1993-2002 F-Body $449.95 pr.
SUBFRAME CONNECTORS
SFC001 - Hardtop Boxed Subframe Connector(1993-2002 F-body) $169.95 pair
TUBULAR K-MEMBERS KM002-1
$499.95
BMR BOLT-IN MANUAL RACK AND PINION CONVERSION RK002$695.95
TRANSMISSION CONVERSION CROSSMEMBERS TCC004
$179.95
CONTROL ARM RELOCATION BRACKETS CAB001 - Weld-in brackets - $79.95 pair
MANUAL BRAKE
CONVERSION KIT
MBK001 1993-02 Camaro and Firebird $199.95
MOSER 12 BOLT REARENDS
PRG230 DRAG RACING - Fully assembled 12 bolt rear (less brakes). 33 spline Pro Race axles, choice of OE 12mm studs or 1/2", 33 spline steel lightweight spool, U1602 S-series 1350 yoke, crossover U-joint, u-bolts, chrome cover and Strange or Motive PRO gearset. $2149.95
OPRG10 --Upgrade to aluminum support cover +$115.95
BOGART WHEELS Bolted R/T
221-BOG-RT$1,724.00 with lugs
check texas speed
Mickey Thompson 3055S - Mickey Thompson ET Drag Slicks $190 eh you need 2 $380
Mickey Thompson 3007 - Mickey Thompson ET Front Drag Racing Tires$148.95 you need 2 @300
OEM Replacement Carpet
TP53320 93-02 Camaro/Firebird Carpet w/ Hatch $289.99
MOMO steering wheel Race $232
Chevrolet steering Hubs $71.25
CORBEAU FX1 Pro $299.00 eh you need 2 $600
F-Body 10-Point Roll Bar Kit, 4130 Cromoly Weld-in
Part #: FWOL230CM Crossbar Option : Weld-In (Std)
Door Bar Style : Straight Style
Jig Notching : Jig Notched
Rear Bar Option : Thru Side Plastic to Wheel Well (Std)
Shipping Option : Shipping to Residential (USA) $150.00
$685.46 + labor $400 =$1085
MADMAN RACING i have reciept
glasstek dash board $260
guage panel $35.00
stroud window net kit $275
front half cage install $500
cut cowl dzus fasteners
new windshield and moulding $269
shop fees and frieght $175
i have the receipt from madman $2995
this car has $13750 in parts. most of the work was performed by wizzard or madman and others labor cost would be around $3000 more also have tach and gauges not the cheap stuff around $400
the car does need to be wired. it does not come with motor or trans or fuel system. everything is used $5500.00 located in louisiana this car does have a 10 point cage
XTREME
TORQUE ARM
Lower A-arms:
SUBFRAME CONNECTORS
$499.95
$179.95
MANUAL BRAKE
CONVERSION KIT
check texas speed
guage panel $35.00
meissen
Aug 11, 2015 06:05 AM
