1995 Formula A4 383 Stroker
Old Jul 15, 2009 | 09:52 PM
calfirebird's Avatar
I'm forced to sell my baby. I have owned this car since 99 and have loved every day of it. I now have a child and my wife was laid off from work so we are now selling off the toys. Let me know if you have any questions. The specs are below. I have Pictures on Fquick http://www.fquick.com/garages/viewga...id=2152&page=1
Asking 6500 OBO
1995 Firebird Formula. T-Tops forest green, 383 stroker, Has a Strange S-60 rear end with 373s with about 1500 miles on it, 4l60e transmission built by perfomabuilt performance transmissions level 2 with a 9.5” vigilante 3600 stall convertor with about 1000 miles on it. chromoly Driveshaft. Cross drilled and slotted rotors with Red Calipers. 1 ¾ long tube headers with Hooker Cat back exhaust. Dyno tuned by Ed Wright here in Tulsa 417RWHP 496RWTQ. Engine has 3500 miles on it with eagle crank Sir 6 Rods Ketih Black pistons with 10.6/1 compression Cam is a GM 847 (234/242 dur @ .050 lift, .539/.558 lobe lift with 1.5 rockers, 112 LSA.) With Comp Cams Roller rockers and lifters. Has lucus 42lb injectors 58 MM Throttle body by BBk with a Power coated Red Intake manifold. Electric water pump. The Clear Coat is starting to peel off on the front drivers fender and on the roof.
Old Jul 19, 2009 | 10:08 PM
lt1xondeck
Mar 18, 2016 07:22 PM
Drtryder
Apr 22, 2015 04:17 PM
D1SC383LT4
Jan 26, 2015 01:41 PM
