2001 z28 som 600+ rwhp!!!!
I am testing the water on my 2001 z28 camaro sunset orange metallic a4. It has t-tops and a kenwood cd player wired for a system with infinity interiors. This car is a stripper and is awesome. it has gray cloth interior interior is all in all in good condition: Exterior has nnew som paint. It has cold a/c nedds a final tune but runs awsome just had an oil leak in the rear may be the rear main sealstart today may be a rear main i dont have money to fix it. I have reciepts on the motor and tranny, nitrous and other stuff. I also have the flow sheets on the heads. I have thousands invested just in receipts. I will sell the car for $8500 or possibly part it out. CLEAN TEXAS TITLE! call or text 512-913-2846 please leave a message if I do not answer. If I do not sell it by Saturday i will just fix it and keep it.
MOTOR
-rebuilt LS1 with less than 1000 miles on it
-diamond forged pistons
-Forged H-Beam rods
-36lb injectors
-walbro 255 fuel pump
-Fully ported 5.3 heads milled to 45cc that flow 315cfm on intake at .550 and 232 cfm on exhaust no pipe on a 3.9 inch bore 2.02 1.57 valves patriot gold springs
-new melling oil pump
-Double roller timing chain
-brand new LS7 lifters
-comp hardened pushrods
-arp rod bolts and head bolts
-trex cam shaft v1
-11.1 compresssion
-texas speed 1 7/8 ceramic coated long tube headers to off road y-pipe to an electric cut out
-ls6 intake
-80mm throttle body
-slp lid
-ported mass airflow sensor
Transmission
-yank 3400 stall converter
-fully built 4l60E
rearend
-moser 12 bolt 33 spline axles 1350 yolk
Nirous
-200 hp wet shot cold fusion nitrous kit
-upgraded 15 lb bottle filled never used
-msd window switch
-msd timing twister included not installed yet
-zex remote bottle opener
-need to be finished installing
chasis and wheels
-Y2K vette wheels chrome 18s in the rear 17s in the front.
-1.5 lowering springs
-tubular control arms
-adjustable pan hard bar
-hotchkis rear and front sway bars front is not installed yet
-Edelbrock 3 pt strut tower brace
-tubular weld on subframe connectors
MOTOR
-Forged H-Beam rods
-36lb injectors
-trex cam shaft v1
-11.1 compresssion
-ls6 intake
-80mm throttle body
-slp lid
Transmission
-fully built 4l60E
rearend
Nirous
-msd window switch
chasis and wheels
