1998 Camaro V6 3800..Need suggestions
I have a 98' Camaro V6 3800 Series
The car runs good even with the flywheel having loose bolts.lol
Well I was thinking to fix that problem so I thought I might as well buy a new clutch&lightweight flywheel..
but then again that's a lot of cash..
So I came about 2 solutions..
Rebuild my V6 that I have&supercharge it
or
Swap the engine to a LS1 or LT1 or something similar
Specific suggestions will be more than helpful ! =)
thankyouuu
or
thankyouuu
A new clutch and flywheel is a lot less money than any of your other options.
Before you consider a swap, I suggest that you sell it and buy and LS1 or LT1 car. It will cost a lot less.
1999 LS1 M6 with 103k on the clock for $3900:
http://www.autotrader.com/fyc/vdp.js...r_id=259931052
If you want to supercharge or turbocharge your V6, more power to you, but you're looking at spending a lot of money just to go as fast as a stock LS1.
I thought it was a Z28, with the LS1 in it. I wasn't paying attention. It's a 3800 V6 like you have now.LS1 is a V8, found in '98-02 Z28s and SSes. LT1 is the older V8, found in '93-97 Z28s and '96-97 SSes.
Okay, how about these?
1998 Z28, 137k, $3999
2001 SS, 106k, $6949
hotrodyou1
Dec 20, 2014 10:05 PM
mspennyhughes
Nov 28, 2014 03:22 PM
Desolate_Flux
Jul 23, 2002 08:24 PM
