Can't get my leak to go away
Old Jun 9, 2009 | 12:50 PM
69gto96z's Avatar
I built my motor 2 years ago, and it NEVER leaked a drop. Last summer I was driving down the highway, and there was something in the middle of my lane. I couldn't get over, and couldn't swerve to miss it, so I tried to straddle it. Turns out it was a big chunk of something, it smacked my oil pan, putting a hole in it, and cracking my tranny. I got a new tranny, and replaced the oil pan and gasket. The car has leaked oil ever since. I have replaced the pan gasket again, and it still leaks oil. I am thinking maybe the impact ruined my rear main seal? Its not a huge leak, but anytime I got WOT, it blows oil all over the place and smokes everywhere. Rear main sound like the culprit? Also, my clutch is completely dry.
Old Jun 9, 2009 | 12:55 PM
bw_hunter's Avatar
Perhaps the impact cracked the front cover....
Old Jun 9, 2009 | 07:27 PM
69gto96z's Avatar
The leak is coming from the rear of the motor, the front is competely dry
Old Jun 9, 2009 | 10:34 PM
budgetlt1's Avatar
back of the intake manifold? i just replaced my intake gasket because the intake was leaking and my bellhousing was covered, then it would get onto my exhaust and smoke. no leaks since. no smoke.
just a thought
Old Jun 10, 2009 | 02:12 AM
69gto96z's Avatar
I was thinking that, but it didn't start until the car took a hit. Which makes me think it's on the bottom end. I'll check it tomorrow to make sure
Old Jun 10, 2009 | 04:53 AM
ACE1252's Avatar
When you replaced the gasket, did you seal the front and rear of the pan? If not, "The Right Stuff" will fix the issue. I put it all the way across the front and back, laid the pan gasket in place, laid a bead on the gasket(front and back), then put the pan in place.
Old Jun 10, 2009 | 10:22 AM
bw_hunter's Avatar
Where is the oil. If it's on the front of the flywheel..the side opoosite the clutch, and your inspection plate is in place then the rear main seal seems like the primary culprit. If the oil is outside of there and forward of the bellhousing the something else is the issue. Does one side seem worse than the other? Where is oil getting on the exhaust?
Sorry about all the questions.....
Old Jun 10, 2009 | 12:41 PM
69gto96z's Avatar
The oil is on the inspection plate, and there is a black spot on my passenger side header where itnis burning. As for the oil pan gasket, I gave it a nice coat of rtv when I put the gasket in. What is the rear main housing made of? Isn't it plastic? It's been a long time since I've seen one, just can't remember. I'm thinking maybe the impact cracked the rear main housing.
Old Jun 11, 2009 | 10:00 PM
SSTAT's Avatar
Its aluminum. and IIRC the last two oil pan "bolts" are actually studs that come down out of the rear cover (or something like that). So a direct hit to the pan does actually translate to a direct hit to the rear cover. You might be on to something. Its the same crappy fragile aluminum the front cover is made out of.
Jeff1904
Jun 5, 2016 05:00 PM
magman
Apr 15, 2016 03:08 AM
blac94Z
Nov 4, 2015 01:59 PM
drt
Sep 27, 2015 04:39 PM
colts0455
Sep 27, 2015 01:07 PM
