95 Trans Am. $3400 355 6 Speed (TX)
SOLD
Looking to sell my 95 T/A and get into something a little more practical for long trips as I will be going away for college soon. The title is in my name and all the details are below. If you have any questions or want more pictures the best way to reach me is by e-mail, and I should get back to you the same day. Or if you wish call and leave a message and I will try to get back to you as soon as I can but e-mail is easier.
Don't message me as it is already full and i don't get on here very much anymore.
Serious offers with cash only please. More pictures upon request.
1995 Trans Am M6/T56 (6 speed)
~108k on body
Engine:
LT1, 355 Bored .030 over (rebuild was 7k ago)
Eagle Crank, Forged Eagle Pistons, and rods
Stage 2 heads
Comp Cams "Extreme" LT1 Camshaft, 230 / 236, .510 / .520 112 LSA
Moroso Cold Air Intake
Hooker Long Tube Headers
Hooker ORY
Borla Cat-Back
Comp springs, 918's
1.6 crane gold rr's
Chromoly push rods
Melling Performance Oil Pump W/ high pressure spring
Thunder racing Lifters
Suspension/Drivetrain:
Hotchkiss Adjustable Panhard bar
Hotchkiss Rear Control Arms
Hotchkiss Sway Bars
Hotchkiss Subframe connectors
4.10:1 Motive gears
G2 Rear End Girdle & Stud Kit
G2 Lower Control Arm Relocation Bracket
Skip-Shift Eliminator
B&M Ripper Shifter
Appearence:
ZR1’s Gun metal Polished Lip 17x9/17x11 315’s out back(minor rubbing)
Rear exhaust port on bumper painted Black
The bad:
Only real problem is the car is burning some oil. Which it will smoke a bit at idle and you'll get a nice puff of smoke if you get on it.
Other things include the clear is starting to haze and come off on the hood as well as a oval spot on the fender and door. As of right now getting it cleared again would fix it. There is a tear in the drive seat and a split on the steering wheel leather. The bracket on the shifter that holds the boot is broke. The a/c also doesn’t blow to cold. Passenger side t-top lock is missing and the headliner is starting to hang. The ABS light has been on since the motor has been pulled.
Also if your looking to get the car a little cheaper I have some 98+ silver camaro snow flake wheels that I can throw some tires on and we can work out a deal so just let me know.
Asking: $3400 as is in pictures. Serious offers only please. (Also i will throw in the old engine that came out of it. Had around 50k on it)
E-mail: Whothe136@yahoo.com
Phone 972 742 8712 Brian
~108k on body
Engine:
Stage 2 heads
Hooker ORY
Borla Cat-Back
Comp springs, 918's
1.6 crane gold rr's
Chromoly push rods
Hotchkiss Sway Bars
4.10:1 Motive gears
B&M Ripper Shifter
Appearence:
The bad:
F'n1996Z28SS
Aug 23, 2023 11:19 PM
