3.4 makes a racket through the CAI above 2500 RPM
Old Aug 12, 2008 | 12:55 AM
Northwest94Z's Avatar
I've recently run into a problem with the 3.4 in my dd Firebird. The shop I entrust some of my repairs to told me that the camshaft is bent causing the engine to miss at higher rpms and I need a rebuild.
I just did new plugs and wires and the car idles beautifully and drives fine below 2000 rpm but when I accelerate above about 2500 rpm there is a rapid backfiring type sound that comes out of what sounds like the CAI. I'm wondering if the real problem is a bad or bad injectors? The injectors have 140k on them and the engine has 56k (the original crapped out at 86k so I installed a new GM crate 3.4). I'm thinking the motor is still relatively new to have a camshaft problem but the injectors if plugged/ clogged could cause a higher rpm problem since their workload increases with the RPM's.
Anyone have some sound advice or ideas?
Should I buy a new set of injectors or could something else be at play here?
Old Aug 29, 2008 | 09:36 PM
Let me try to simplify what I'm experiencing.
While the car is stationary I can redline the engine without issue.
While under load the rpm's struggle to climb above 2500 RPM.
Would this be indicative of a fuel problem?
Old Aug 29, 2008 | 09:44 PM
95grncamaro's Avatar
clogged cat maybe
Old Aug 30, 2008 | 02:13 AM
No Cat.
alex5366
Feb 17, 2015 09:07 AM
Cam's maro
Jan 30, 2015 09:21 PM
D1SC383LT4
Jan 26, 2015 01:41 PM
edman
Jan 25, 2015 02:41 PM
TheV6Bird
Aug 27, 2002 10:38 PM
