Rocker Studs
Old Jul 15, 2008 | 03:10 PM
RallyBoy1's Avatar
Question Rocker Studs
What are the chances of breaking a 3/8's inch rocker stud with the lpe 211/219 cam, self-aligning 1.6 comp pro mags and 99893 valve springs? I was told that the 402 lb/in rating on the springs was too high and it would probably break the stud. What kind of spring rate will stock rocker studs vs aftermarket 3/8 and 7/16 studs hold?
Old Jul 15, 2008 | 03:21 PM
mdacton's Avatar
It may but a good stud probly wont break on a hyd. cam.....
Old Jul 15, 2008 | 07:12 PM
RallyBoy1's Avatar
Anyone else wanna chime in? How many of you have broken the 3/8 rocker stud?
Old Jul 15, 2008 | 07:13 PM
RallyBoy1's Avatar
I wanted to keep it simple and i did not want to fool with guide plates.
Old Jul 16, 2008 | 09:53 AM
RallyBoy1's Avatar
bump
Old Jul 16, 2008 | 12:43 PM
Joe B's Avatar
.....Whoops......I Double posted
Old Jul 16, 2008 | 12:44 PM
Joe B's Avatar
It's actually pretty common for even good 3/8 rocker studs to break in a moderate performance application (I see it all the time).....No one can give you an accurate "exact" limit when breakage Can (or will) occur, but Increased spring pressures(over stock), Increased RPM's(over stock), and the use of Self aligning rockers....ALL bring you MUCH closer to the breakage threshold of 3/8 rocker studs...3/8 studs also flex like crazy when compared to 7/16 studs....this increased flex creates a lot of deflection and inaccuracies in the running valve-train that inturn brings you closer to stud breakage (among other parts)....... On my engines, I personally use nothing but (NSA) 7/16 rockers, 7/16 ARP studs, guideplates and "good quality" hardened push-rods......if everything has to be purchased new to begin with, the only added expense is about $30 bucks for guideplates and aprox $100 for a set of decent push-rods (which IMO, any performance engine build should have anyway, if it's cared about)........and I see your going with a 383 with LE-2 heads....I'd get the good stuff to begin with............Joe
Old Jul 17, 2008 | 04:58 PM
RallyBoy1's Avatar
Thanks Joe and Mdacton for your responses. Does anyone else have anymore data that they would like to add?
13qtr
Oct 28, 2016 08:11 PM
football4life
Oct 4, 2015 07:48 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
mmf_1013
Sep 12, 2015 08:56 PM
Daluchman1974
Sep 11, 2015 06:12 AM
