Hard to start after driving
Old Jul 13, 2008 | 06:58 PM
detroit1994z28's Avatar
I been having starting problems with my 94 camaro z28 after driving it for a while. It will start up fine all the time but when I drive it for awhile it has a hard time to start up- the longer I drive the car - the harder it is to start. Could this be -caused from the starter getting hot
Old Jul 14, 2008 | 12:22 AM
applecorn37's Avatar
I would guess the ignition coil is getting hot. It's bolted directly to the block so it soaks in a lot of heat directly. A lot of guys put a few washers in between the block and the ignition coil to help with that. Give that a try and see if it helps.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
HectorM52
Jul 30, 2017 11:46 AM
Alex Barnes
Jan 24, 2015 10:21 PM
Queens94z28
Dec 20, 2014 09:11 PM
