Blown tranny from a shifter change?
Old Jul 7, 2008 | 11:32 AM
gonzoflick's Avatar
So I just picked up a 2000 3.8 from a friend for dirt cheap. Its got 131k and drove smooth as can be the first two days. Its a 5 speed with stock shifter. I decided to take the Hurst shifter (with short stick) off my 96 thinking it would fit the '00 and it did. Drove around all day.
Get on the Interstate tonight and have her up around 75. The shifter pops out of gear and into neutral and I cannot shift to any gears, it grinds. I slow to the side and think "well **** I've not done something right". The car starts but when I engage it into gear and release the clutch nothing happens. Ive replaced the Hurst back with the stock clutch and same thing. Also If I release the clutch when the shifter is in N it stalls.
The shop tells me today its "something in the tranny" and quoted $1400 to install a used t5 transmission. Could I really have blown my tranny just from switching shifters? Please any advice appreciated.
Old Jul 7, 2008 | 07:12 PM
slingshot's Avatar
It sounds like the short shifter was out of adjustment and some of your syncros are screwed up. Ask the shop if they would just replace the syncros, and see how much it would be...1400 is that to repair and to replace? I mean a manual transmission isnt that bad to replace, and it is cheap to rebuild one.
Old Jul 7, 2008 | 08:47 PM
gonzoflick's Avatar
wow so my shifter can cause this sort of damage to a transmission? What sort of damage from my repair shop am I looking at for repairing synchros? They now can get me a used T5 for $950 installed.
Old Jul 8, 2008 | 12:23 PM
redneckgames's Avatar
like I said on the other forums. Want your money back? as is?
Old Jul 9, 2008 | 07:49 AM
JooneJune's Avatar
I'm saying its an install problem, your not shifting into gear, try installing the stock unit again and then give it a spin...
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
BigWil
Mar 29, 2015 12:24 PM
VF-124
Mar 16, 2015 08:14 PM
tds1213
Nov 27, 2014 12:55 PM
