3800 spark plug help
Old Jun 4, 2008 | 08:44 PM
81z28phil's Avatar
My friend brought me his 3800 1999 camaro to do a spark plug change. The car was boiling when it got here so i was able to take a quick peek at the spark plugs and the rear plugs seem to have a bracket around them. I need it done tomorow but havnt touched the bracket yet to see if it moves out of the way or what. If anyone can help me out with the braket situation that would be great. Im trying to find out now so tomorow i can jump right on it and do the change.
Does anyone know anything i should be aware of computer wise or w/e?
Old Jun 4, 2008 | 08:55 PM
SupplySgt.'s Avatar
as far as i know there shouldn't be any computer issues to look for. The brackets should come off as far as i know as well. at least they do on my 96. Now the tricky part is getting to the spark plugs. I ended up having to come in from underneath on mine as well. that was interesting to say the least
Old Jun 4, 2008 | 11:02 PM
briggsbuilder's Avatar
that guy just wanted to sell u a computer...... i know i work for a auto parts
Old Jun 5, 2008 | 08:20 AM
81z28phil's Avatar
Well I know where and how to reach the plugs but how do I get the one with the bracket covering it, off? Its the two ones in the back...they have that piece of crap header protection around them.
Old Jun 5, 2008 | 04:25 PM
81z28phil's Avatar
Ok Today i was able to get 5 of em changed and the last one which is the middle on behind the header on the passanger side i left for the mechanic to do it that was too much of a headache for me if anyone could tell me how they got that one just for future reference that would be great thanks. also thanks for the help.
Old Jun 8, 2008 | 02:17 PM
camaroLevi's Avatar
Lightbulb tip
heres a tip for FUTURE refrence ....put anti-seeze on the threads b4 you install them....that aw2 help u for the FUTURE,, oh if u mean tool wise u use an 5/8 extension ratchet with very good patience
Old Jun 9, 2008 | 12:21 AM
ImportKILLER's Avatar
If you have headers, getting to the spark plugs is much easier. I know that when I had the stock manifolds, it would be a pain. With the pacesetters, the plugs are right there...piece of cake.
And yes, a little bit of anti-seize goes a long way the next time you have to pull the plugs.
Old Jun 9, 2008 | 01:55 PM
redneckgames's Avatar
not exactly sure what bracket you are talking about. I have changed the plugs on my fiance's 98 with the 3.8 before. I done them all from the bottom. It made it alot easier. I did however make the mistake of putting autolites in it. Never again. Started it up and it had a miss. Changed to ac delco and ran perfect. The second time around I could change them in about 30 minutes.
jayblev95
Jun 7, 2015 04:04 PM
markzzzz
May 8, 2015 09:21 AM
blkWidow
May 3, 2015 08:42 AM
nikko
Apr 20, 2015 07:56 AM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
