Quick questions about gaskets and bolts for my MACs
Old Mar 12, 2008 | 10:00 PM
lbrowne's Avatar
This should be the spring that my mac mids are finally going on. After my clutch of course!
The headers came with bolts, and gaskets. But I'm thinking I should get better gaskets and possibly locking header bolts. I am on a bit of a budget. I've seen threads about using fel pros but I'm not getting the proper part numbers I think.
I would rather not use the bolts with the little clips as I heard they're annoying - are the ones with the center tightening piece better? (hold it in place with a wrench, use an allen key to tighten the inside)
Thanks guys - wife just gave the green light on the clutch purchase so thats on the way, so I'm going to throw in a couple extra pieces if I can get them for a good price.
Old Mar 13, 2008 | 12:04 AM
caldercay's Avatar
I'm not well-versed with the nuances of the TransAm, but if it's got an LT1
(which I'm sure it does), then you want the FelPro FPP-1470. It's what I
used on my 95 Z28 mating Kooks headers.
On the bolt side, I chose stainless steel (cause headers are) socket-head
bolts (you know - you use an allen wrench). I find it's a much cleaner installation:
http://picasaweb.google.com/calder.c...32328402025650
Dont go to Sears or ACE (they want $2/piece for the bolts). I went to a
local "fastener" shop (mostly cater to the commercial industry) and bought
all 12 stainless steel bolts for $5 !! (same dang-durn bolt).
Old Mar 13, 2008 | 08:21 AM
lbrowne's Avatar
That seems like a good idea about the bolts - I suppose I could take one of the bolts from the MACs' box and use that to get the correct size...
Old Mar 13, 2008 | 02:55 PM
2000GTP's Avatar
The bolts you are referring to are the Stage 8 brand, they are kind of annoying and hard to install with those clips. Breslin was a popular choice, but they are no longer in business. Alot of people are also just using 1" ARP bolts and have had good luck with those. As for the header gaskets, I was using the Fel-Pro 1406 ones. I'm not sure about the 1470s, although it seems that is the part number people are using so I don't know.
Old Mar 13, 2008 | 03:52 PM
Green96Z's Avatar
I went with the ARP bolts. They are nice because of the small 5/16" head, so its easy to get a wrench on them. I went with Percy's Seal 4 Good gaskets first, but blew those out when my bolts backed out. I went with the Fel-Pro 1470's after that because of availability and reference from a local LT1 mechanic. Work good so far.
Old Mar 13, 2008 | 05:40 PM
NJ-LE's Avatar
Smile
lbrowne:
My MAC setup came with copper gaskets which I used and have had no problems. I had some 316ss 3/8" x 1" Allen Head bolts plus washers and used those. Just recheck tightness a few times over the first few weeks after installation. Also, I used some of the Permatex 101BR "Ultra Copper" high temp silicone as a combination thread lube and anti-vibration compound on the bolts. Used that on the #1 tube slip-joint and on the O2 sensor threads too. No leaks and the O2 sensors are still working well. Check the #1 tube slip-joint fit and make sure it's snug before installing. I used a T-bolt clamp on mine.
Good Luck
Old Mar 13, 2008 | 06:47 PM
Green96Z's Avatar
Use anti-sieze instead. The heads are aluminum and you risk siezing a bolt in there, and stripping out the threads in the head later. Same for the O2 sensors.
Old Mar 13, 2008 | 06:51 PM
dangalla's Avatar
i would and did use factory gaskets, and i used the arp 1 inchers and have not had any issues
Old Mar 14, 2008 | 08:03 AM
2000GTP's Avatar
I'm curious, have you had issues with aftermarket exhaust gaskets causing you to stick with factory only replacements?
Old Mar 14, 2008 | 08:15 AM
dangalla's Avatar
no not personally, but i read so many horror stories about them and the cost of factory is almost the same it did not make sense to not use them
Old Mar 16, 2008 | 11:21 AM
lbrowne's Avatar
OK, got the felpro 1470s and the copper high temp silicone.
So for bolts, the local shop has ARP - but I was really leaning towards trying to get those allen tightening bolts like I mentioned above. Anyone have an arp part number?
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Queens94z28
Dec 20, 2014 09:11 PM
startingstock
Exhaust System
Dec 12, 2014 06:40 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
