LT1 Stock and Performance Parts
Old Feb 24, 2008 | 10:18 PM
95Zedder's Avatar
Stock Parts
95 SRS ECU - This is the Air Bag ECU that is located in the passenger
kick panel. This needs to be replaced if the bags have went off. In
perfect condition.
$20
Driveshaft - This is the stock steel driveshaft in a LT1 Auto car. It
has brand new Precision U-Joints in it about 30 miles ago.
$30
Front and Rear Sway Bar - Stock Sway bars in good condition.
$25
Performance Parts
MSD Distributor - This is a MSD Pro Billet Distributor 8570 for a SBC.
It has an adjustable slip collar, small diameter cap and rotor for
tight clearence and a Comp Cams Composite Gear designed for steel cams.
$200
Aeromotive Fuel Pump - This is the Aeromotive SS Series Fuel Pump, it
is designed for up to 750hp on a carburated motor and has less than
1000 miles on it.
$125
Edelbrock Intake - This is an Edelbrock Super Victor intake for a SBC,
it has the 4500 dominator carb opening. Great for top end power. Mint
Condition.
$150
VFN Hood - This is a VFN Custom Hood for 93-97 Camaros. It has a 4.5"
Cowl and come as close to the windshield as possible and clears the
wipers. It was painted with the same red paint that comes on Camaros
at a local body shop. Requires Zues fateners to be mounted. Pics Avaliable.
$400
Battery Relocation - This is the Allstar Battery mount for the spare
tire well. As well as the Painless Battery Relocation 0 guage Power and
Ground wires. The Power wire is over 20ft long and the ground is about 4ft.
$60
Spark Plug Wires - This is a set of MSD Super Conductor wires for a
standard SBC. Includes all 8 plug wires and the coil wire.
$50
Speedo Interface - This is a Dakota Digital Speedo Signal Interface. It
is used between the electric speedo sensor on the transmission and
the electric guage in the car. It lets you use a TH400 tranny with the
stock guages and recalibrates for gears and tire size.
$45
Oil Pump Pick-Up - This is a Canton Oil Pump Pick-Up for a M55 Oil
Pump and there Oil Pan. This was for another project that never was
used.
$10
Meziere Water Pump - This is a meziere electric water pump for LT1
engines. It comes with the water pump housing and water neck with a
160* thermostat.
$175
Polyurethene Motor Mount - This is a Energy Suspension Polyurethene
motor mount for the passenger side of the motor.
$20
TCI Valve Body - This is a TCI Full Manual Reverse Pattern valve
body for a 700r4. It includes both gaskets and the seperator plate.
This one is the more expensive one that has full engine braking.
$250
4000 Stall Converter - This is a 4000 Stall Anti-Balooning Torque
Converter for a 700R4. It was bought out of a place in Florida. It is
a great converter with no slipage in the top end of the 1/4 mile. The
Anti-Balooning plate is used to protect the engine during nitrious use
or incase a cooler line gets crimped and heat expands the converter it
won't damage the engine. Great Condition, less than 1000 miles.
$300
All items are priced before shipping. Shipping costs will depend on
zip code. I will also accept reasonable offers. Pics avaliable upon request.
oldschool
Feb 9, 2016 09:21 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
