Removed Stock Elbow, What is this?
I took off my stock elbow to check out my throttle body, and I was just confused when I saw this.
That seems like it would just heat up and force hot air into the intake.
A shampoo bottle cap will work just fine. I had some thick fiberglass and made a plug. Pro's - easier to work on your engine in the future. Con's - maybe more noise from air flowing through your elbow (not even noticeable though). Matter fact the 1LE elbow doesn't have a cutout for the silencer.
Ditch the "donkey dong". It just gets in the way.
I used a deodorant cap and a hose clamp. Ended up replacing it later on with the 1LE elbow. It does increase intake sound, but if you have a CAI that little bit doesn't really matter. Opens up some room too (always welcome on the F-body engine bay).
Thunder Racing has a couple of resonator delete plugs as well that will take the place of that. Other option would be to go with an aftermarket elbow such as the Trickflow or 1LE.
i took this off when i hcanged to my k&n cai, and forgot to cover the whole up. car kept stallin out when i turned into places. lol. i swear on my life i was scared the car was done... 2 weeks after buyin it. lol. used duck tape here as temp til i get a niceer elbow
