CC-503 Cam-shaft
Old Feb 14, 2008 | 01:49 PM
Dave1980's Avatar
CC-503 Cam-shaft
Cam is good condition ,and all lobes are ok. 20k on it. Here is the pics with specs (for 1.5 rockers.) This cam has the long pin(already to stock specs for the vented opti). It can be cut down to spec for the earlier years.
$125.00 Paypal accepted
Old Feb 15, 2008 | 10:12 AM
Dave1980's Avatar
bump
Old Feb 16, 2008 | 10:20 AM
Dave1980's Avatar
ttt
Old Feb 17, 2008 | 09:41 PM
Dave1980's Avatar
ttt
Old Feb 18, 2008 | 08:45 AM
86 Iroc-Z28 310CI's Avatar
Can this be used in a 86 up 350?
Old Feb 18, 2008 | 09:06 AM
9formula4's Avatar
Yes it can. Remember it is .503/.510 with 1.5 rockers and .536/.544 with 1.6 rockers
Old Feb 18, 2008 | 09:11 AM
lol im new to cam tech so what does that mean?
Old Feb 19, 2008 | 12:02 AM
CCA-08-503-8 thats the cam I really need. Do you know what makes this one diff?
Old Feb 19, 2008 | 02:26 AM
tspence45's Avatar
I looked it up on Summitracing, and apparently, his cam can only be used on LT1 engines. http://store.summitracing.com/partde...w=32&N=700+115
Old Feb 19, 2008 | 01:47 PM
Dave1980's Avatar
Why? I highly doubt that. It even has a mechanical fuel pump lobe on the front of the cam that goes unused in our cars? It is no different than any other SBC cam to my knowledge.
Old Feb 19, 2008 | 01:58 PM
Dave1980's Avatar
I would call comp and ask I did not see anything different on there page. It may just be a reference from LT1 cams.
Old Feb 19, 2008 | 03:31 PM
BA383TA's Avatar
It will work. My son has one in his 87 GTA.
Old Feb 19, 2008 | 06:48 PM
its the dowel pin its alittle longer just needs to be shortend. I have to consult a friend of mine and maybe This weekend Ill have the cash I will let you know deff interested in it though.
Old Feb 20, 2008 | 02:20 PM
Dave1980's Avatar
Ttt
Old Feb 20, 2008 | 03:09 PM
Bigrick2324's Avatar
you can use this in small block chevy it just hydraulic roller not flat tappet but my buddy used a cc306 in his and worked just fine but ya these are based around the lt1's
