96-97 swappo
Old Feb 10, 2008 | 01:24 PM
josh_89's Avatar
96-97 swappo
im purchasing a 96-97 lt1 crate motor for my 95 z28 and im wondering if it will be a direct drop in or if there is other things i'll need to purchase?
Old Feb 10, 2008 | 01:28 PM
OBE1 95Z28's Avatar
I have a 96 motor in my 95; you'll need to use your 95 knock sensor. The 96 also has a crank position sensor mounted in the timing chain cover. This is not used on the 95 so there is no issue. I'm assuming the new motor comes with the crankshaft hub. If it doesn't, you can't use the 95 hub as it is long than the 96-97; you'll have to buy a 96 style hub. Everything hooks up and runs fine.
Old Feb 10, 2008 | 01:32 PM
ssbowtie1's Avatar
Sorry to hijack but where are you getting your crate motor from?
Old Feb 10, 2008 | 03:15 PM
josh_89's Avatar
i work at a gm dealer and there having a motor blowout sale, my cost is $1500
Old Feb 10, 2008 | 03:16 PM
josh_89's Avatar
thanks alot for your help, before i install it im going to install lt4 heads and a peformance cam
Old Feb 10, 2008 | 03:22 PM
Stl94LT1's Avatar
Are there any more available at that price?
Old Feb 10, 2008 | 03:31 PM
josh_89's Avatar
i really dont know, i can find out when i go back to work on saturday cuz im in school all week. the 93-94 lt1 was 3k and the 95 was 3k but the 96-97 was only $1500 and makes it kinda hard to say no because it would cost more to make it on my own
Old Feb 10, 2008 | 03:32 PM
ssbowtie1's Avatar
Wow ya I wouldn't mind picking one up at that price either and giving you some compensation too for your help. Shoot me a pm if tis possible.
Old Feb 10, 2008 | 03:38 PM
Stl94LT1's Avatar
Oh, I just noticed you are in Canada. I was hoping you were somewhere close to the Midwest.
But, congrat's on the great deal!!
Old Feb 10, 2008 | 04:04 PM
josh_89's Avatar
1500 is a good price for a new crate lt1 that i can use to put a new heart into my 150,000km z28 and prior to install im gonna install lt4 heads with hot cam. then.......take the lt1 from the camaro and rebuild it for my 74 k5 (full convertable) jimmy 4x4. then...... take the 79' 350 and rebuild it for a chevette or my 92 mazda 323 hatchback (winter beater).... and I figure that if im putting lt4 top end on the new motor then i can used the new heads from the new motor for the old lt1 when it gets an over haul, which will leave me with a spare set of used lt1 heads. total cost for all three projects (lt4 camaro/lt1 k5 jimmy/350 sleeper)shouldn't exceed 8-10k by the end
GREEN3112
Feb 10, 2019 09:19 PM
Ringmaster72
Dec 12, 2017 10:12 PM
dantheman8119
Parts Wanted
Oct 20, 2003 02:35 PM
DaveZLT1
Oct 19, 2003 02:22 PM
rlax31
Aug 22, 2003 12:49 PM
