650+ HP LT1 Solid Roller Carbureted Engine
Old Feb 9, 2008 | 10:08 AM
95Zedder's Avatar
I have here an LT1 Solid Roller Engine that is capable of 10 second
passes in a full weight camaro at over 120MPH but is tame enough to
drive to work and back.
1995 LT1 Block
BOred 0.030 over
Decked to 9.000 dech height
Line Bored and Honed
Clevite 77 H Series Main & Rod Bearings
Durabond Performance Cam Bearings
Eagle Billet Splayed Main Caps
ARP Main Studs for Splayed Caps
ARP 12-Point Head Studs
Eagle ESP 4340 3.875 Stroke Crankshaft
Eagle ESP H-Beam 6.00 Connecting Rods
Forged Flat Top SRP Pistons
Speed Pro File Fit Piston Rings
Crane Cams Custom Small Base Circle Soild Roller (262/266 .704/.704)
Cloyes Billet Double Roller Timing Chain
Comp Cams Endur-x Solid Roller Lifters
Comp Cams Custom Length Hi-Tech Pushrods
Moroso Fabricated Aluminum Center Bolt Valve Covers
AFR 227cc CNC Competition Ported LT4 Heads massauged by Agostino Racing that flow 312/228 @ .700 w/ SBC bolt pattern
Manley Severe Duty 2.100/1.700 +.250 Valves
Crane Cams SOlid Roller Springs (226 seat, 717 open)
Crane Cams Titanium Reatiners and 10* Locks
Jesel SS Shaft Mount Rockers 1.6/1.6 w/ .250 Spacer Plate
Melling Performance High Volume Oil Pump
ARP Oil Pump Driveshaft
Canton Oil Pump Pick-up
Canton 7qt Road Race Oil Pan
Fluidampr LT1 Balancer
ATI Flexplate w/ SFI spec
SBC Edelbrock Super Victor 4500 Intake Ported to AFR Heads
Holley 1050 Dominator w/ Soft Progressive Linkage
CSR Billet Aluminum 4500 Throttle Cable Bracket
MSD Pro Billet Mechanical Distributor w/ Comp Cams Composite Gear
MSD 8.5 Super Conductor Sprak Plus Wires
Meziere LT1 Electric Water Pump 43GPM
LT1 Alternator Reloction Plate w/ 140AMP GM Alternator
GM LT1 Starter
Has about 1000km on it and about 15 passes at the track.
It Was Professionally Built at Engine Technology in Cambridge, ON
in the fall of '06
Engine makes 658HP @ 7000RPM and 568ft/lb @ 5500RPM
Has 11.6:1 Compression and runs at 35* Timing on 93 Octane.
Very Streetable Engine, I use to drive to the track an hour away
race the car and drive it back no problem. With this engine in my
car it went 10.80 @ 124.5MPH in a 3650LB Car and could probably go
faster if I had a trans brake. I also use to drive it to work 45mins
away once or twice a week last summer.
I need to get $9200 for it as I have a little over $15000 in it.
I will also sell it for $8200 without the intake, carb and distributor
so you can stick a miniram on it and run fuel injection.
Its a great motor but that new GM LSX is calling my name.
Pics avaliable upon request.
Old Feb 9, 2008 | 08:33 PM
95z28man's Avatar
Can you post some pics or send to 95z28guy@comcast.net
Old Feb 10, 2008 | 05:47 AM
FASTFATBOY's Avatar
Impressive.
This is a steal....good luck.
David
Old Feb 12, 2008 | 06:46 PM
95Zedder's Avatar
Here are some pics of the engine at the machine shop and in my car right now.
Old Feb 12, 2008 | 09:49 PM
texas94z's Avatar
that is the sickest n/a lt1 ive ever seen. i cant wait to see what you do with a lsx.
Old Feb 12, 2008 | 09:59 PM
FASTFATBOY's Avatar
This engine is very comperable to what I have, he has more cam, but I have more compression...so that kinda evens out.
Put a Super Victor#2925 on this engine converted to EFI with an elbow and let er rip.
man I wish you were around about 8 months ago...I would have been ALL OVER this with both feet.
Bump fer a screaming deal.
David
oldschool
Feb 9, 2016 09:21 PM
95chwagon
Jan 13, 2015 09:19 PM
siguy
Nov 27, 2014 10:07 AM
Wicked
Jul 25, 2002 04:19 PM
Ed95Pont
Jul 23, 2002 08:26 AM
