Best recommended intake gasket for port matched heads and intake
You should try to use the gasket that your porter matched to.
For instance, my heads and manifold were port matched to the LT4 race intake gasket part # GM12367777. That way, I never have to trim the gasket unless the gasket is mis-stamped.
Can you ask the guy who port matched your intake/heads which gasket he used?
http://www.airflowresearch.com/parts.php scroll to the bottom
go mic them and buy a set. my ports are bigger than any LT4 gasket, race or otherwise. the lt1's are even smaller. by the way yes they are for a SBC not a LT1 but they will work fine.
oldschool
Feb 9, 2016 09:21 PM
95chwagon
Jan 13, 2015 09:19 PM
