Starting a car thats been sitting for a year..
Old Feb 2, 2008 | 02:15 PM
MadKilla's Avatar
I think I finally located the reason my Z wouldn't start. I fixed a dead spot on the main wire harness. Before I start it I wanted to see of there was anything I should do before cranking it over. Is the gas going to be bad? Oil? I have never started a car thats been sitting full of fluids for this long.
Old Feb 2, 2008 | 02:51 PM
IROCThisZ28ForLife's Avatar
i would def change ALL the fluids, especially the gas. I beleive you also have to prime the pumps first as they would be dry i would imagine
Old Feb 2, 2008 | 06:33 PM
nader454's Avatar
I think it will start right up if the battery is charged. Then I would put fresh fluids in it after it's back in service.
Old Feb 2, 2008 | 08:56 PM
maverickmk's Avatar
that's what I would do
Old Feb 3, 2008 | 10:19 PM
tonka toy's Avatar
I would pull the fuse for the fuel injection and (with a fully charged battery) crank it over until you get oil pressure.that way your at least not starting it with the bearings being bone dry I would check all the fuids before start up,then change them after it's up and running.
jj71787
Dec 30, 2014 02:15 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
jayblev95
Dec 1, 2014 06:55 AM
teedoff59
Aug 8, 2002 01:36 AM
