CC503 or HotCam ?? Daily Driver !!
So I have seen many threads about what cam is better, the 503 or the hotcam, and it seems like the 503 is better on power and driveability. So should I just go with the 503 over the hotcam or what ?? Will the 503 be too much for the stock heads and how will it idle compared to the HotCam ?? Thanks
As I have read,searched the 503 is about as big as you will want to go on stock heads. If you get the HC kit it will have all you will need if the idle is all you want.Check on youtube and other palces for idle diff.
503 cam is good but so is the hc hotcam gets better gas tho to cc503 produces great power also tho both great for dd with stock heads buddy im going cc306 with stock heads but also have everything else i need but cc503 and hc both great cams oh hotcam you can survive with out tune unlike cc503 but its always better to get tuned afterwards
either of the two will need a tune no matter what to get your moneys worth out of the swap. i have the hotcam and on stock tune it idled at 650 or so and it sounded nasty i loved it but it wanted to stall coming to stops. hotcam is a great i love it for what it is. the cc503 is a bigger cam so its going to idle alot more lumpier and gain a bit more power over the hotcam. reason why i went with the hotcam is due to emissions and the hotcam has a hard enough time trying to pass and the 503 is bigger so i wasnt going to bother with the problems that are going to arise down the road.
For sound purposes, here's my lt4 hotcam idling thru pacesetter longtubes, ORY, and maganflow catback.
http://videos.streetfire.net/video/1...e2012adcac.htm
my 503 is fine for everyday driving, although traffic is not fun as my car likes to slingshot off the line into the rear bumper ahead of me because of the torque.
the hotcam is for whimps, the 503 is for slightly less whimpy men, so get the 503
I never had to do emissions w/ the Hotcam on the stock tuning so I can't say if it would pass or not, but after it was tuned I went and did emissions. I compared previous emissions test data on my car, and the hotcam on a mail-order tune ran cleaner than the stock cam on stock tuning. In some areas it had less than HALF of the emissions as stock.
