Ok So I Went Out And Bought A Grade 8 Rod And Still Cant Get This Hub On!! (sorry)
sorry about posting this again but i got the grade 8 rod finally and im using 4 washers to get the job done but i swear im using all the force i can and this d*** hub wont budge !!! i so tempted to just beat on it with a hammer but iv been warned to not to
(UPDATE its supposed to stop here right???)
The surfaces should be absolutely clean with no burrs. You can do a very light oiling on the surfaces. It also helps to have a thrust bearing to reduce friction. You can oil the rod, as well (where it is contacting the nut). It also needs to be going on absolutely straight.
