Healthy motor or clogged oil - 40 psi idle
Ive noticed ever since Ive had the car its had good pressure (got it w/ 30k on it and I put 10k on). Its around 38ish fully warmed up and idling. During driving near 60. Is 38-40 high for idle?
Sounds like a bad sender.
From the factory, GM only mandated 6psi @ 1,000 rpm, and 18psi @ 2,000 and 24psi @4,000.
Too much oil pressure can contaminate the combustion chamber and effect BFSC numbers significantly!
Change the sender. Or perhaps-- what weight oil are you using?
5w-30, just switched over for the winter. Here is the odd thing...last summer I ran my oil for maby 4k which was pretty long and it was diry and then when I changed it it seems like the oil pressure went up a good 8psi or so. Normal?
Start with the sensor or get a test gage and check it.
I agree with Z28SORR~
The best and only way to tell is with a manual mechanical gauge.
(The "plugged" port near the oil filter might be an easier option to connect an auxillary mechanical gauge, since the stock oil sender is quite difficult to get to)
Alex Barnes
Jan 24, 2015 10:21 PM
