Problems after car sat for 2 months
well, my car has been in the same spot for about 2 months now. It has been started 3-4 times in that, but that was all before christmas time. (dec. 20th is the last time it was ran). Now, heres the story
-Ive been doing some work on it, where it was on jackstands.
-It was ran twice for about 10 minutes total open headers
-The front was 6-8" higher than the back of the car
Now, I started it today, and it was puffing white smoke and leaking out a water mixture out of the exhaust.
I popped the hood, and there was very faintly white smoke coming out, couldnt tell where from though.
Now, it didn't haev a bad headgasket or anything when I put it on the stands, it was actually mechanically perfect.
Just wondering what your thoughts are. I'm thinking the watery mixture out of the exhaust could just be condensation in the exhaust piping and such since its been a while. Maybe the white smoke out of the exhaust is cause the gas has sat that long?
White smoke means oil, prob leaking past the valve guid seals. water in the exhaust is probably just condensation, unless it dosnt go away after warm up or smells like antifreez.
What kind of work did you do to it? sometimes you can get greasy handprints on the exaust manifolds and or spill some oil on them and when you crank it up afterwards it will burn off causing the smoke. Or you could have something toutching the exaust so double check everything.
oh well, its gone now...but, i dont want to know how it likes it when im gone for 4 years and its in storage
NewsBot
Dec 3, 2014 12:30 PM
