Rough idle after dead battery or new tune...Is this normal?
Okay whenever I install a new PCM tune or the battery goes dead I get a rough idle for a short time that does eventually go away. The idle is set at 950 RPM but will drop to around 500 RPM or so then climb back up to normal.
After about the second or third short drive this issue is gone.Engine runs great with no other issues period.
IS this the PCM just learning and populating cells and blocks?
Is this normal?
Is this normal?
yeah, it has to relearn. Mine does that too... its kind of annoying at stoplights, as mine seems to die, but after a couple times drinving and shutting it off and starting it, it eventually relearns the blms and stuff..
Oncomingstorm22
Jan 22, 2015 07:15 PM
with the tune being off.
