ford 30 injectors question
i have a question for you guys using motorsport 30 injectors. this week i tried to install them and on my 95 lt1 the injectors have a solid round cut out space that the clip slides into on the rail clipes in and the injectors fit deep in the fuel rail these ford 30 injectors have a half groove where they are supposed to be mounted, but a little higher there is a solid circle like my stock ones but if i use that one it pushes the injectors real close to the outer edge, meaning the o-ring. wondering if there is a clip i need to modify or did you all use them with the top grove leaving the o-ring close to the edge. just afraid of fuel leaks. any info woud be appreciated
thanks in advance
pat
thanks in advance
pat
when i instaled with out the clip.i coud push them down and the oring wood allmost come out .not good .just scared of them poping out .they are very close .sarey for the spelling i have deslexia .
ChrisFrez
Dec 15, 2014 03:09 PM
ChrisFrez
Dec 7, 2014 06:01 PM
NewsBot
Dec 3, 2014 12:30 PM
ChrisFrez
Nov 30, 2014 08:41 AM
ChrisFrez
Nov 23, 2014 10:33 AM
