93 lt1 Oil coming out of my water pump port
Old Dec 7, 2007 | 12:30 PM
bigbadjons's Avatar
Angry UPDATE! 93 lt1 Oil coming out of my water pump port
I just put on a new set of 61909 Edelbrock heads, i used Fel pro gaskets 260-1650 ,went to put the oil in,befor i put on the water pump,and i saw oil leaking out of the top port on the passenger side, water pump port.i dident have the Valve covers on.i was just putting the oil through the holes in the head. want to check it out befor i put any more time in.
Old Dec 7, 2007 | 12:33 PM
GaJoe's Avatar
little more info....what kind of heads? which head gasket did you use?
Old Dec 7, 2007 | 12:53 PM
bigbadjons's Avatar
Fel Pro- Edelbrock
Fel Pro- Edelbrock Looper Pro Told Me Thay Would Be Ok
Old Dec 7, 2007 | 01:06 PM
96m6lt1's Avatar
are the heads you just installed designed for an Lt1?
sounds to me like you have regular sbc heads on your Lt1,possibly wrong gaskets too.
Old Dec 7, 2007 | 01:11 PM
bigbadjons's Avatar
heads
Nope, i called edelbrock and thay are the right heads.but the guy was like blown away. he told me there is no possible way that could be happening.
Old Dec 7, 2007 | 03:25 PM
GaJoe's Avatar
can you post a pic? also any chance you can post the part number of the heads and the part number for the head gaskets you used?
Old Dec 7, 2007 | 04:01 PM
FASTFATBOY's Avatar
Those are the wrong heads for an LT1, the oil return holes to the valley are directly over the water pump inlets in the block on an LT1. You most likely have GEN1 heads on a GEN2 block....make sure the heads were not boxed wrong. Pull your valve covers and shine a light into the water pump hole the oil is coming out of and see if you can see the light through the oil return hole in the front of the head.
David
Old Dec 7, 2007 | 06:11 PM
Xws666X's Avatar
that sux..
Old Dec 7, 2007 | 06:52 PM
bigbadjons's Avatar
this could be it
a buddy of mine was helpping me and he put ultra blue around the water ports on the head gasket,what a buddy a
Jazsun
Dec 29, 2014 12:14 PM
Queens94z28
Dec 20, 2014 09:11 PM
pologreen97z
Dec 2, 2014 10:42 AM
thenewkid
Nov 27, 2014 09:41 AM
