wanted camaro
Old Nov 27, 2007 | 02:17 AM
hopingforz28's Avatar
wanted camaro
i am looking to purchase a camaro z28 preferably an lt1 low mileage is a plus. im looking for a car located close to long island NY if you have anything e-mail me at metsman1989@yahoo.com im looking to spend somewhere in the vicinity of 5000 dollars maybe more if i have to get it delivered. my name is tim either post your car here or email me information
thank you
Old Nov 27, 2007 | 02:34 AM
95 camaro z28's Avatar
what do you think of mine??
im flexible on the posted price...now looking to get about 6 for it. and will ship no problem! can have shipped out asap.
http://jeepforum.com/forum/showthread.php?t=451965
Old Nov 27, 2007 | 03:00 AM
yea that car is nice... how many miles are on the car itself? and how long ago did you bore out the engine, and do everything else to the car?
Old Nov 29, 2007 | 09:12 PM
dre2013's Avatar
how about a low mileage trans am?
https://www.camaroz28.com/forums/sho...d.php?t=552725
4800..negotiable..send me a pm if interested
Old Dec 2, 2007 | 08:31 AM
eddies26's Avatar
sill looking I have this for sale
95 camaro part out gauging interest
I am almost done with my car & it has to go 5000 whole car picked up in maryland or parted out see prices below. Email with any questions I have shipping available but would prefer to get rid of the whole thing at once.
esymonds1@comcast.net
240-216-0063
use this to see pics of the car
95 z-28 106000
built 96 vette 4 bolt main block
forged 30 over pistons
11.0-1 comp
shot peened rods
arp rod bolts
stock crank size(was perfect when rebuilt)
high pressure gm oil pump(holds 45 at idle 65-70 at 2000)
6 quart vette oil pan
lt4 cam kit with gm roller roackers
manley valves
hardenes comp pushrods
new gm perf parts lifters
stock lt1 heads port matched to intake
jett hot coated intake manifold
k-member w.new motor mounts
58 mm edelbrock throttle body
all new sensors
egr removed & blocked off
polished valve covers with correct notch for alternator
new vented optispark upgrade
taylor 10mm wires
new ac compressor
built auto 4l60e with extra clutches shift kit installed- ENGINE TRANS,ECU,WIRING W LT1 EDIT FOR 3500 PLUS SHIPPING
jett hot coated edelbrock shorty headers LOOK NEW!!-250 W/Y PIPE
new ac lines-100
moroso cold air intake-50 filter needs cleaning
aluminum radiator 200
steel braided transmissions lines with all fittings-50
new u joints (stock drive shaft)-25
stock locking rear-100
new brakes up front(calipers,pads,rotors,brake lines)W/SPINDLES-100 BOTH
traction bars LAKEWOOD-50
KYB AGX adjustable struts & shocks front & rear-150 W/NEW STRUT MOUNTS
new steering rack W/NEW TIE RODS-75
abs removed & proportioning valve installed with line lock kit(steel needs to be wired up, still have abs if you want to reinstall)75
new battery-25
magnaflow stainless exhaust cat(sounds mean)200
MAGNAFLOW HIGH FLOW CAT 3"-50
INTERIOR
swapped in 98 up dashboard & stereo(monsoon bose system sounds great)-300 W/STEREO BOSE SYSTEM
98 up center console-100
98 trans am buckets in perfect shape & rear seat also-150
t-top shades(grey but can be dyed)-75
BLACK DOOR PANELS-75 BOTH
BLACK QUARTER PANELS-50
REAR BLACK PLASTIC-50
REAR HATCH-100
REAR HATCH NEW LIFT SUPPORTS-35
3 GAUGE POD-25
HOOD-75
REAR BUMPER ASSEMBLY-50
DOORS W/NEW LIFT MOTORS INSTALLED-100 EACH
T-TOPS-150 SET
T-TOP HEADLINER BLACK-50
BLACK VISORS-25
FRONT BUMPER W/HEADLIGHTS FIBERGLASS SHOT ALL LIGHTS WORK-50
FAN ASSEMBLY-25
STOCK LT1 RADIATOR USED 1 YEAR OLD-50
4 STOCK SALAD SHOOTERS 3 W 50% TREAD OTHER BALD 50
car after strip come get it for free you remove -FREE
SEND ME OFFERS PLEASE SOMEONE TAKE THE WHOLE CAR!!!!!!
deadmanrunning
Jan 3, 2015 01:12 PM
ChrisFrez
Dec 21, 2014 09:47 PM
Hurin
Dec 13, 2014 07:38 PM
Dec 4, 2014 11:56 AM
