CM612 Springs with LE2?
Humm... just got a set of reworked LE heads from a friend. these heads would be equal to a LE 1.8 (ported before packages were out) they came with comp 3/8" 1.6 SA rr's with brand new ARP studs, and a set of CM612 springs, would the LE2 cam be stressing this combo to much for a DD? should i be thiking about a LE1.5 cam instead? any input would be appreciated!
I broke one of those valvesprings with .545/.555 lift on a 230/236 XE comp cam, I definitly would never use those springs again. I was restarting the motor and it snapped the valvespring right in 2. In other words, I would never use those springs again, and I haven't even seen them for sale in months/years.
Lloyd used to use the 612's on all his LE1 heads/cam kits a while back. He doesn't recommend running them on anything bigger than .550 lift, 224 duration and more than 6200 RPM. However I have the exact cam that 96LT1TX has and I've been running the 612's for 2 1/2 years now without problems (fingers crossed)... I guess it's a hit or miss type of thing, but either way they will be coming out soon.
That said, assuming you already have the LE2 cam, I would run a better spring instead of downgrading your cam choice to accomodate a weaker spring just because it's what's installed on your heads now... Do it right the first time.
If your still figuring out your heads/cam combo, and end up getting a LE1 type cam, just so you know, he runs the crane dual valvesprings on his LE1 heads now (crane #10308) he told me those were good for up to 580-590 lift cams and much more RPM than the 612's.
Your best bet is to get your cam choice figured out and speak to Lloyd like OldSStroker said.
I would also look at the beehive springs. I have the comp cams beehives (26918s) but everyone has been hating on them lately. There is a PAC valvespring built to same specs as this, and I believe it should be good to around ~600 lift (I hope, because I am running more lift) and good for the rpms easily. I am set up for about a 6700rpm rev limiter, but then again I have only had the springs on for a few thousand miles. Check out the PACs though, there was a group purchase in the group purchase forum for them a few weeks ago, that will tell you where to get them and how much they usually are.
thank for the input MTL, i have wanted to go with the LE2 cam for years now, so im pretty set on getting new springs now, heh anyone want a set of 612's? lol i have talked with lloyd about this already and i am definatly goign to replace the springs... would i also need to replace locks, retainers and clips?
2QUIK6
Jul 27, 2015 08:23 PM
ChrisFrez
Mar 29, 2015 09:43 PM
Bignasty85
Mar 3, 2015 04:05 PM
